coolface man
Stickers on inclined face
coolface man
Hi everyone
i'm having issues on applying a decal on an inclined surface using inventor
here's a screenshot to let you understand my situation.
Using the decal tool I cant select the surface on where i put the image (the selected one, to let you understand)
Thank you for the help
Edited by coolface man
Share this post
Link to post
MarkFlayler
Whats wrong it with it? Showing just an image of an unconsumed sketch doesn't help.
What error are you receiving? Are you getting an unexpected result? Does this work on a simplified model?
Share this post
Link to post
coolface man
you're right, i'm sorry
just updated the post with the details of the issue
Share this post
Link to post
MarkFlayler
I assume you are in the assembly environment, you need to be in the part mode for the decal to work.
Share this post
Link to post
coolface man
no, it doesn't work even in the part mode :/
Share this post
Link to post
MarkFlayler
Is the part proprietary? Can you attach it if not or produce a simple example that shows the issue.
Also make sure all your Service Packs and Hotfixes are installed.
Share this post
Link to post
coolface man
i'm uploading a video to show the issue clearly. Can i put here the link?
Share this post
Link to post
MarkFlayler
I see no reason why not.
Share this post
Link to post
MarkFlayler
ok, i definitely see what you mean. What feature has built that face you are trying to attach to?
What is your Inventor version? Service Packs and Hotfixes installed?
Are you in the Part mode when you are doing this video?
Share this post
Link to post
coolface man
the face i'm trying to use is created using the chamfer.
I'm working on Inventor 2016 and everything is up to date.
yes i'm in the part mode
Share this post
Link to post
MarkFlayler
Works just find on my system. What is your Inventor build number?
Go to About Autodesk Inventor from the little bubble in the upper right.
Share this post
Link to post
coolface man
is build 138
Share this post
Link to post
coolface man
ok thank you, i'll try and see if it works after the update
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
