3d polyline vertices
silviu
hello,
is there any possibility to set the 3d polylines so i can always see the vertices of every polyline in a draw? or a lisp that can do it?
thank you
you know how you see a selected polyline with the grip ( small square) around every vertex. i wonder if can set the display to always see that. i need that to see without selection, where the vertices are situated on polylines. there are some software with the possibility to "show vertices" ( especially gis software). i am working with autocad map 3d 2009. thank you.
Re: Grips. Consult your Help files. I doubt that you can display them continuously (i.e. - without making a slection).
You might also try checking Tools > Options > Selection tab.
