I really hope someone can help me here because I am at my wits end here.
I have a program that I am working on, which I tried to do complete in just VBA, which was a failed attempt; but I can do it in LISP, so I am using the VBA to LISP techniques. The only problem it looks like you can only pass pre-defined AutoCAD variables between VBA and LISP (i.e USERS1, USERS2, USERS3, USERS4, USERS5). Is this correct?
Anyways, to get to my question I need to pass many file names (as strings) to LISP, a lot more than the 5 user fields allow and because of the restrictions on variable names erasing after the module closes I have to get them all out at one shot.
I thought this code below would work; but I forgot the "Getvar" LISP command requires quotes which confuses the VBA SendCommand.
[color=black]   ThisDrawing.SetVariable "USERS1", ProcessList.List(0)[/color]
[color=black]   ThisDrawing.SendCommand "(setq UserList (getvar "USERS1"))"[/color]
[color=black]   For i = ProcessList.ListCount - 2 To step - 1[/color]
[color=black]       ThisDrawing.SetVariable "USERS1", ProcessList.List(i)[/color]
[color=black]       ThisDrawing.SendCommand "(setq UserList (cons (getvar "USERS1") UserList))"[/color]
[color=black]       Next i[/color]
Anyways, this is probably not the best way to do it; but like I said I am at my wits end here. Does anyone have any way to make this work?
ProcessList = List Box
I hope I have provided enough information.
Thanks in advance.
Olhado,
I don't have a complete answer for you, but for extra user variables there are at least two ways. You can set environment variables in Windows. I have not done this myself, but I have heard that it can be done. I don't know how much space is available for user variables in the environment. Maybe someone on the forum can give specifics. You can also open a text file in Autolisp, write and read anything you want, then delete or keep the file as you wish. I have done that many times and it works well. Hope this helps.
Oh by the way remember to close the file else you will get a read error.
Dictionaries is the best way of AutoLISP VBA interchange.
How to put data from autocad' objects to excel. for example values of text into excel table!
