pmxcad Posted July 29, 2016 Posted July 29, 2016 Hello, question: can i use the ! within a gatte script? I am using the script for attribute fill in the drawing foldername. i just fills in "!d" ; ; TEST ; ; ZOOM ALL ; (setq CurrDwgName (getvar "dwgname")) (setq a (getvar "dwgprefix")) (setq b (getvar "dwgname")) (setq c (strcat a b)) (setq d (vl-filename-directory c)) (setq e (vl-filename-base d)) (setq f (vl-filename-base c)) (setq g (strcat e "-" f)) (setq Fname (substr CurrDwgName 1 (- (strlen CurrDwgName) 4))) (setq name (strcat (getvar "DWGPREFIX") FNAME ".pdf")) gatte block OH-PSD NAME DISCR-02 !d thanks PMXcad Quote
BIGAL Posted July 29, 2016 Posted July 29, 2016 Why not make all the code a lisp then you would imply d as a lisp variable. (load "xxxxx") (command "gatte" "Block" "OH-PSD" NAME "DISCR-02" d) Quote
pmxcad Posted July 30, 2016 Author Posted July 30, 2016 I have tried, but gatte wont run in à lisp. I need something like (c:gatte). Because it calls the gatte lisp in à lisp. (Read it on internet). But stil nog working. Pmxcad Quote
pmxcad Posted July 30, 2016 Author Posted July 30, 2016 Not working, Put it in a script or lisp i get: Command: (command "gatte" "Block" "OH-PSD" NAME "DISCR-02" d) gatte Unknown command "GATTE". Press F1 for help. PmxCAD Quote
BIGAL Posted July 31, 2016 Posted July 31, 2016 Ok it may be like using extrim in a lisp you must Load it first then you start it with a different command. (load "extrim") (etrim) Quote
BIGAL Posted July 31, 2016 Posted July 31, 2016 (c:gatte) works try (c:gatte) (command "Block" "OH-PSD" NAME "DISCR-02" d) Quote
pmxcad Posted August 1, 2016 Author Posted August 1, 2016 Nope, not working. in a sript or lisp. prompt: Command: (c:gatte) Select block or attribute [block name]: (command "Block" "OH-PSD" "NAME" "DISCR-02" d) after (c:gatte) it stops en ask to select and doesnt go on with the script/lisp. PmxCAD Quote
BIGAL Posted August 2, 2016 Posted August 2, 2016 After a few more goes why not just use a lisp to change the correct attribute value and ignore Gatte. ssget will get the correctblock if you apply a couple of filters if say in a layout the filter can be "paperspace" (setq ss1 (ssget "x" (list (cons 0 "INSERT") (cons 2 bname)(cons 410 tabname)))) (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 0 )) 'getattributes) (if (= tagname (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr) ) ; end if ) ; end foreach Quote
tombu Posted August 3, 2016 Posted August 3, 2016 Nope, not working. in a sript or lisp. prompt: Command: (c:gatte) Select block or attribute [block name]: (command "Block" "OH-PSD" "NAME" "DISCR-02" d) after (c:gatte) it stops en ask to select and doesnt go on with the script/lisp. PmxCAD Assuming block name is OH-PSD with attribute name NAME you want to read DISCR-02 then this script should work for every insert of that block in the drawing: (load "gatte.lsp")(c:gatte) Block OH-PSD NAME DISCR-02 Yes Couldn't figure out what the d was for. Quote
pmxcad Posted August 6, 2016 Author Posted August 6, 2016 Hello tombu, the "d'" used in the first post to call the folder name. i mostly use a ! to call the variable in a script but it does not work with GATTE. (load "gatte.lsp")(c:gatte) Block OH-PSD NAME DISCR-02 Yes This works to get gatte working but i cannot use the !d or d to get the variable (folder name) Thanks, PmxCAD Quote
