betterway Posted August 16, 2016 Share Posted August 16, 2016 AutoCAD P&ID 2015 Help. Would like to know if a custom view can be created for the Data Manager that includes a column for TAGS. Currently created a view of Skids with Level 1 as Engineering Items.SKID. However there is no column for TAGS. Can one be added somehow? Quote Link to comment Share on other sites More sharing options...
Jach Posted August 19, 2016 Share Posted August 19, 2016 I have done it in AutoCAD P&ID 2014, so should not be a problem. Under project setup, there should be something called Reports, in there you can modify or create some new Defined Reports. When you have defined what you want on your report in the data manager, you will be able to find the Report in Project Reports inside the Data Manager (look for the dropdown menu on the top left of the data manager) Quote Link to comment Share on other sites More sharing options...
