Invisible File Name in Title Bar
Madam
Hallo,
Im working in AutoCad Map 3D 2012 under Windows 10. I have a problem with visiniti of the name file (and drawing path). It is visible only in with reduced window, in fullscreen regime it is invisible (the title bar is white).
Thank you for help.
Adam
Examples:
reduced window with the file name and path: C....situace.dwg
2012 AutoDesk products, (actually anything older than 2016) are not supported to run in Windows 10. There is no quick and easy fix for these sorts of issues. The software is not compatible.
You can look into a "Virtual" operating system like Longbow, which can emulate earlier Windows releases.
