BIGAL Posted September 22, 2016 Posted September 22, 2016 Following on from posts by YZ and the need to update some blocks enthused me to look at a problem with CIV3d to do with trees, via a PM I know Lee has helped YZ to do the following for export from Magnet. This will find cogo_points and add a dynamic block for tree trunk size and spread based on the point description. ie an inner and outer shape. Just a quick comment we have a 3rd party app that did work and when it was updated it stopped working. ; Dynamically insert a tree based on civ3D point description ; By Alan H Sep 2016 ; version 2 read a csv file for non Civ3D users ;; Set Dynamic Block Property Value - Lee Mac ;; Modifies the value of a Dynamic Block property (if present) ;; blk - [vla] VLA Dynamic Block Reference object ;; prp - [str] Dynamic Block property name (case-insensitive) ;; val - [any] New value for property ;; Returns: [any] New value if successful, else nil (defun LM:setdynpropvalue ( blk prp val ) (setq prp (strcase prp)) (vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (progn (vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x)))) (cond (val) (t)) ) ) ) (vlax-invoke blk 'getdynamicblockproperties) ) ) ;; CSV -> List - Lee Mac ;; Parses a line from a CSV file into a list of cell values. ;; str - [str] string read from CSV file ;; sep - [str] CSV separator token ;; pos - [int] initial position index (always zero) (defun LM:csv->lst ( str sep pos / s ) (cond ( (not (setq pos (vl-string-search sep str pos))) (if (wcmatch str "\"*\"") (list (LM:csv-replacequotes (substr str 2 (- (strlen str) 2)))) (list str) ) ) ( (or (wcmatch (setq s (substr str 1 pos)) "\"*[~\"]") (and (wcmatch s "~*[~\"]*") (= 1 (logand 1 pos))) ) (LM:csv->lst str sep (+ pos 2)) ) ( (wcmatch s "\"*\"") (cons (LM:csv-replacequotes (substr str 2 (- pos 2))) (LM:csv->lst (substr str (+ pos 2)) sep 0) ) ) ( (cons s (LM:csv->lst (substr str (+ pos 2)) sep 0))) ) ) (defun dynamic_trees ( / obj obj2 raw inspt ) ;(if (not LM:csv->lst)(load "ReadCSV-V1-3")) ;(if (not LM:setdynpropvalue)(load "set-dynamic-block-value")) (setq layold (getvar "clayer")) (if (not (tblsearch "LAYER" "EX_TREE")) (Command "-layer" "m" "EX_TREE" "c" 90 "EX_TREE" "LT" "Continuous" "EX_TREE" "") (setvar "clayer" "EX_TREE") ) (setq ss (ssget "x" '((0 . "AECC_COGO_POINT")))) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1))))) (setq raw (vla-get-description obj)) (setq inspt (vlax-safearray->list (vlax-variant-value (vlax-get-property obj 'location)))) ;RawDescription = "TR 5 1.5" replace tr as required add extra tree types also ; use space delimeted description - tree trunk spread (if (wcmatch raw "TR*") (progn (setq rawlist (LM:csv->lst raw " " 0)) (setq basedesc (nth 0 rawlist)) (setq spread (atof (nth 2 rawlist))) (setq trunk (atof (nth 1 rawlist))) ; convert string (if (= "TR" basedesc) (progn (command "-Insert" "TREEDYN" inspt 1 1 0) (setq obj2 (vlax-ename->vla-object (entlast))) (LM:setdynpropvalue obj2 "Trunk" trunk) (LM:setdynpropvalue obj2 "Spread" spread) ) ;progn ) ; if ) ;progn ) ; if ) ; repeat (setvar "clayer" layold) (princ) ; exit quitely ) ;defun (dynamic_trees) treedyn.dwg Quote
