asperotti415
Viewport Help
asperotti415
Hi,
I can't seem to pan or zoom, and the viewport is NOT locked. Please help. I keep having to delete the viewports and start over. Easy fix but time consuming when I have to recreate a dozen layouts.
Thank you!
Share this post
Link to post
rkent
You will have to post a drawing exhibiting that problem. You may not be able to attach a file yet in here, leave in a drop box somewhere and post the link.
Share this post
Link to post
Dana W
If its a large drawing file size wise, it could simply be an overwhelmed video processor issue. Did you try the REGEN command when this occurs?
Share this post
Link to post
Dadgad
Welcome to CADTutor! :)
This will sound like a strange question, I know, but how did you get INTO the viewport?
How many viewports are there in the layout?
What is your current VPMAX system variable setting?
Share this post
Link to post
halam
Two viewport on top of each other?
audit, purge, copy to new file
Share this post
Link to post
Dadgad
That is a good hypothesis, and always confusing when it happens.
Try selecting the viewport (or viewports) with a crossing window, and look in properties or quick properties, to see what is really there.
Meaning, how many viewports.
Or you could turn on Selection Cycling to see if there is something hidden.
Edited by Dadgad
Share this post
Link to post
SLW210
No reason the OP shouldn't be able to post a .dwg, they will however need approval for a link.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
