Making dimstyles by picking dimension line? Ver 2008 VBA
Subject: Making dimstyles by picking dimension line? Ver 2008 VBA
If you look at the pdf attachment you will see
various dim object variables for a choosen dimension
line. See file and code.
Is there a way to step thur the dimension object
and set variables for a new dim style?????
Is there a way to make a dimstyle from all (or most) of these
variables to best match the dimstyle that created the
my picked dimension?
I can change a few object variables individually but how can
I get a complete best match dim style from the choose
dimension?
Code:
Private Sub CommandButton2_Click()
Dim objDimension As AcadDimension
Dim varPickedPoint As Variant
Dim objDimStyle As AcadDimStyle
Dim strDimStyles As String
Dim strChosenDimStyle As String
Dim stg As String
On Error Resume Next
Me.hide
ThisDrawing.Utility.GetEntity objDimension, varPickedPoint, _
"Picked a dimension whose style you wish to set"
If objDimension Is Nothing Then
MsgBox "You failed to pick a dimension object"
Exit Sub
End If
stg = "Textheight"
'MsgBox objDimension.TextRotation
'ThisDrawing.SetVariable "CLAYER", objDimension.DimensionLinelayer
MsgBox objDimension.ExtensionLineExtend
ThisDrawing.SetVariable "dimexe", objDimension.ExtensionLineExtend
MsgBox objDimension.ExtensionLineOffset
ThisDrawing.SetVariable "dimexo", objDimension.ExtensionLineOffset
MsgBox objDimension.Layer
MsgBox objDimension.DimensionLineColor
ThisDrawing.SetVariable "DIMCLRD", objDimension.DimensionLineColor
MsgBox objDimension.ExtensionLineColor
ThisDrawing.SetVariable "DIMCLRE", objDimension.ExtensionLineColor
MsgBox objDimension.color
'Dim text color
ThisDrawing.SetVariable "DIMCLRT", objDimension.color
MsgBox objDimension.ScaleFactor
ThisDrawing.SetVariable "Dimscale", objDimension.ScaleFactor
ThisDrawing.SendCommand "Dimscale" & vbCr
ThisDrawing.SendCommand objDimension.ScaleFactor & vbCr
MsgBox objDimension.VerticalTextPosition
ThisDrawing.SetVariable "DIMTAD", objDimension.VerticalTextPosition
MsgBox objDimension.TextHeight
ThisDrawing.SetVariable "DIMTXT", objDimension.TextHeight
'****Text Style
MsgBox objDimension.TextStyle
'ThisDrawing.SetVariable "DIMTXT", objDimension.TextHeight
ThisDrawing.DimStyles.StyleName , objDimension.TextStyle
MsgBox objDimension.TextGap
ThisDrawing.SetVariable "DIMJUST", objDimension.TextGap
MsgBox objDimension.ArrowheadSize
ThisDrawing.SetVariable "DIMASZ", objDimension.ArrowheadSize
'Annotation Text
Set objDimStyle = ThisDrawing.DimStyles.Add("YourNamedStyle")
objDimStyle.CopyFrom ThisDrawing
ThisDrawing.ActiveDimStyle = objDimStyle
'Make your changes here....................
'"YourNameStyle"
objDimStyle.Name = "YourNamedStyle"
End Sub
Thank you,
DimObjects.pdf
