PeteUK
Crosshair Angle?
PeteUK
How do you set the crosshairs to be at an angle of say 30 degrees?
And also, if you open a drawing with the cross hairs already set to an unknown angle, how do you reset them to 0 and 90 degrees?
Cheers!
Share this post
Link to post
Cymro
Hi,
you can change the crosshairs angle with snapang, you can also use snapang to reset them back to 0 degrees
Share this post
Link to post
dbroada
go to Tools|Drafting Settings|Snap & Grid.
Play as much as you like! Normal setting is for rectangular snap for orthoganol work or isometric snap if you are drawing in isometric. If working in isometric CTRL+E will step you around the planes.
Share this post
Link to post
PeteUK
thanks for that.
Ive got a drawing that has an unknown angled crosshair but when I typed in SNAPANG the value is 0.0000 - yet the cross hairs appear around 20ish degrees?
Share this post
Link to post
dbroada
is the UCS set to world or rotated? Type PLAN to see if anything happens.
Share this post
Link to post
rkmcswain
Also note that SNAPANG can be called transparently, so you can change it in the middle of a command.
Command: ._LINE
Specify first point:
Specify next point or [undo]: 'snapang
>>Enter new value for SNAPANG <0.000r>: 1.5r
Resuming .LINE command.
Specify next point or [undo]:  <Ortho on>
>>Enter new value for SNAPANG <1.500r>: 3r
Specify next point or [Close/Undo]:
Share this post
Link to post
Shibuboss
Cross Hair Style.
Is it possible to create a new crosshair style.i mean atleast the style of cursor?
Share this post
Link to post
ReMark
What do you have in mind for a new style?
Share this post
Link to post
Shibuboss
Cross hair style
Hello Sir thanks for your respond.
In my mind, to create a new ( my own ) crosshair style.is it possible?
Please advise.
Share this post
Link to post
ReMark
Not to my knowledge. What exactly is it that you wanted to do?
Share this post
Link to post
jlmdesgn
2008 has a command STP_SETCURRSA which allows you to select a line in your drawing and set the crosshairs to that angle. similarly, there is a command to snap them back to 0. This command no longer is supported in 2010. Anyone know how to easily make this happen? It's far faster to use a key command sequence to do this than a series of menus (assuming it's still even possible). Anyone know?
Share this post
Link to post
lpseifert
I believe the command you refer to is from an add-on or a custom lisp command; STP_SETCURRSA has never been a command in core Autocad.
See here
http://www.hyperpics.com/commands/
You could use UCS > Ob to align the UCS with an object... then use UCS > P to return
Share this post
Link to post
jlmdesgn
I went to that webpage, searched it for the command I'm looking for and it isn't listed. Are you saying that the command is not an AutoCad command? That it's part of a second party program (which may or may not be part of the discussion on that web page)? Is there a way around this where I could program a button or insert a short lisp routine to get me where I need to go? It is a highly useful tool that now is no longer available to me. I hope there is a way to retrieve it!
Thanks for your help!
Share this post
Link to post
lpseifert
I thought I made that fairly explicit in post #12
Add this to your acaddoc.lsp file
(defun c:ue () (command "ucs" "ob"))
(defun c:up () (command "ucs" "p"))
This will make the commands UE and UP. The new command UE will align the UCS to an object; UP will realign the UCS to its previous state.
Share this post
Link to post
jlmdesgn
Thank you for the answer - not for the attitude. I'm sorry if some of us aren't as intelligent as you are. You're superiority was clearly noticed by your knowledge. The attitude "I thought I made that fairly explicit in post #12" only made you appear arrogant. You should have stopped at "intelligent."
Good day
Share this post
Link to post
lpseifert
Whoa Nellie... you should have stopped at Thank you.
Share this post
Link to post
