Export line points and rectangle points to Notepad
structo
Hi all,
i want layer description, start point coordinate, end point coordinates. and rectangles layer description, bottom left point coordinate and top right coordinates to note pad. please have a look for format of notepad.
example for one line data is: Line "Layer1" "45.56,0.23" "45.56,2.56"
Here "Line" is type of object, Layer name=Layer1, Start point of line is=45.56,0.23 and End Point of line is="45.56,2.56"
For Rectangle Data: Rec "Layer3" "45.49,0.12" "45.72,0.50"
Here Rec is Rectangle object, Layer name=Layer1, Bottom Left Rectangle corner point is45.49,0.12 , Top right Rectangle corner point is 45.72,0.50.
please solve by lisp.
Thanks.
Output format.txt
export line rec points.dwg
Good time to learn lisp. Any good lisp book will give you all the answers, what you want is the basics of getting information about an object, google assoc 10 & assoc 11 or vla-get-startpoint, vla-get-endpoint. Also assoc 8, assoc 0. Lastly "write-line"
Just look at the code samples here at Cadtutor for any that have "entsel" there are just so many examples.
Also a rectangle object does not exist it becomes a pline with 4 points but its easy to get the corners.
; copy these two lines to the command line 1 at a time and pick a line.
(setq obj (entget (car (entsel "Pick line"))))
(setq stpt (assoc 10 obj))
Stucto, i would suggest to look at the entopo routine on the site of Lee Mac. As a matter of fact, for any lisp question i would start there in any ways..
Halam,
Thank you for reply. i need export those points to notepad and same notepad should be used for developing drawing by notepad output. is this possible by lisp?
