Hello Everyone,
The dashed/dottes/centre/hidden all of them lines do not show up as they should in model space or in vew printer, a all. I have tried all kind of scales and still nothing! However, when I print, success! They are as the linetype they shuld be.
Does anyone had this kind of problem before?
Thank you. :)
Are they in Model Space or Paper Space?
Do you have the default values of 1 for LTSCALE, MSLTSCALE, PSLTSCALE, and CELTSCALE?
Is your drawing 1 = 1 in Model Space?
Is SHADEMODE set to ?
Hi,
in both! All the scales are 1, I checked them, loads of times and I changed them a lot of times aswell. shademode is 2d wireframe, yes!
Hello, I had a similar problem a couple of months ago. I was able to fix mine by typing in the command HQGEOM and changing the value from 1 to 0. It would be worth a shot.
Are you using Metric or Imperial?
Are you using the corresponding Linetype files? acad.lin = Imperial and acadiso.lin = Metric.
Post a .dwg and end all doubt.
Hello,
Some colegue at work changed something in my autocad (in graphics performance) and all the lines started to show properly, apart from one document! I just copied the drawing into new file, and its working now, but I deleted the old one! Thank you for your help!
Hello,
If you have a supported display adapter, then make sure you are using the recommended or certified driver also.
I just ran across this same issue and it was simply out of date drivers.
Hello,
Ok! It should be a certified driver becuase it's a company, so everything is "official". I will confirm with my colegue anyway.
Thank you.
