Shoey Posted November 15, 2016 Posted November 15, 2016 Hi all I have a simple block in the attached file. I would like to use the vertical grip to stretch the block down and at the same time, stretch it diagonally, maintaining the angle and width. The attached drawing as a block in 3 states. 1. As is. 2. Stretched using the vertical grip. 3. Stretched using the diagonal grip No. 2 is what I want to get right because I will eventually hide the diagonal grip when its correct. So if I select the vertical grip and stretch it down, I would like it to act as No. 3 where the diagonal stretches along the diagonal lines. If I stretch this grip, the diagonal lines do not extend and the angle changes. Hope you understand! I used a chain action for the diagonal parameter. I have tried geometry and dim constraints and other actions but at a loss. If anybody can point me in right direction - that would be great. Thanks for your help. tloop-block.dwg Quote
