Geoffers Posted April 5, 2007 Posted April 5, 2007 recently 'crossgraded' from LT to ADT 2007! still struggling i cannot get the 'imprint' command to work in the way it shows in a 'help' demo; draw a line on a 3d solid; imprint and then pull it up like a pitched roof; is this a bug or am i missing something? Quote
tzframpton Posted April 5, 2007 Posted April 5, 2007 make sure it's exactly on the same "plane" as the roof (or exact same Z value). if your roof pitch is 45 degrees, and your imprint is @ 90 degrees, it's not going to work. basically, the object you want to IMPRINT has to be lying on the object that will be imprinted on. hope this helps. Quote
Geoffers Posted April 5, 2007 Author Posted April 5, 2007 thanks for your reply, i thought i had covered those points but... will try again... Quote
Geoffers Posted April 5, 2007 Author Posted April 5, 2007 nope; drew 3 d solid, moved ucs to the top face, drew line on top face between mid points, 'imprint', followed prompts, line is just a fixed part of the 3 d solid, i cannot grip it to pull up to form the 'ridge of a pitched roof'... i can use 'extrude' to pull up one face but that is not what shows in the demo... Quote
Geoffers Posted April 6, 2007 Author Posted April 6, 2007 OK, Ok, i've cracked it (with the help of another forum!) after 'imprinting' need to press Ctrl to pick the line, then it moves with its faces to form a 'pitched roof' shape! yea, yea, yea, i'm happy now onto 'views and sheets'. Quote
vweavers Posted September 11, 2009 Posted September 11, 2009 I too, was wondering how that worked. I tried other line types, but couldn't get them to work, such as polyline, arc, circle, etc. Possible? Quote
Geoffers Posted September 11, 2009 Author Posted September 11, 2009 :D:D:D I too, was wondering how that worked. I tried other line types, but couldn't get them to work, such as polyline, arc, circle, etc. Possible? Wow, VW that's an old thread!:o:o Anyway have you seen the current thread about printing words onto a cylinder? that uses 'imprint'.:) OH, JUST NOTICED - YOU STARTED IT Quote
