I took a LISP class and a VB class years ago. I just started at a company and there are VB codes linked to tool commands to do simple tasks such as printing out sets of plans. But they dont work. Is there a person or a place where I can send code to have it looked at and see what is going on? Supposedly someone from Autodesk came in a few years ago and set this up.
In the code I am trying to plot PDF's of plans and it does the first sheet and then no subsequent sheets. When I debug it takes me to this section of code:
Public Sub pauseTimer(PauseTime As Single)
'*** Timer for pausing during PDF printing for file copy from c:\pdftemp directory
Dim Start As Single
Start = Timer ' Set start time.
Do While Timer
DoEvents ' Yield to other processes
Loop
End Sub
The do While Timer prompt is where the issue lies. From what I can tell this section pauses the program in order to allow plotting of the PDF, but the timer is having an issue so it only does the first sheet and then times out or crashes the AutoCAD program. I am simply not experienced enough to look at this so any help would be appreciated. I can post up the entire code if needed but it is LOOOONG.
Maybe just copy the code in a text file and zip it.
