structo Posted January 3, 2017 Author Posted January 3, 2017 hi maratovich friend, i am using yours great code. if any possibilities can you modify your code for meters unit dimension(2 decimals, ex: 3.23 x 4.55M ) with previous coding room names? Thank you. Quote
maratovich Posted January 9, 2017 Posted January 9, 2017 Good afternoon. We had new year's weekend. Please draw a sample. Quote
structo Posted January 9, 2017 Author Posted January 9, 2017 Good afternoon.We had new year's weekend. Please draw a sample. Hi Friend, happy weekend here i have attached sample drawing. please have a look. Thank you. Room dimension for meters.dwg Quote
structo Posted January 10, 2017 Author Posted January 10, 2017 Hi friend, its working great, only minor error is developing negative sign in dimension text instead of positive value (need absolute positive numerical values). kindly fix. Thanking you. Quote
maratovich Posted January 10, 2017 Posted January 10, 2017 I did not expect that you will choose from top to bottom, right to left. Done. Verify. RoomDim 7.zip Quote
structo Posted January 10, 2017 Author Posted January 10, 2017 Wow, its gunshot code. Thank you very much for your great help. Quote
AP Kumar Posted July 25, 2022 Posted July 25, 2022 Hello, Request, Can you please share in Lisp for Room Label for Imperial and Metric. Regards AP Quote
SLW210 Posted July 25, 2022 Posted July 25, 2022 2 hours ago, AP Kumar said: Hello, Request, Can you please share in Lisp for Room Label for Imperial and Metric. Regards AP If you have AutoCAD LT a LISP will not work. Quote
AP Kumar Posted July 25, 2022 Posted July 25, 2022 Hello, I am Using AutoCAD full Version. and I have tried RoomDim lisp which is similar to Roomlabel lisp. But it only works in Metric Units, I want to use it for feet and Inches. Kindly guide me. Regards AP Quote
BIGAL Posted July 26, 2022 Posted July 26, 2022 Did you try roomdim5 and roomdim7 to see difference. I did not test but looks like what you want. I am sure Maratovich will confirm. Quote
