dave buckberry Posted January 10, 2009 Posted January 10, 2009 Can Anyone Help I have 1500 Blocks on a drawing i need some help in changing all of the tags in the blocks that have the same name ie: chair to chair2 the update the block with vba their are only 4 tags in the blocks and the name to change could be in any of the tags i have counted the block on the screen and have there block names but i just can't update the block can anyone help this is the code that i have Private Function GetAttributes() As Collection Dim i As Integer Dim objBlock As acadBlock Dim AttObj As AcadAttribute Dim Tag As String Dim Value As String Dim oEnt As AcadEntity For i = 0 To Me.lstDestination.ListCount - 1 For Each objBlock In ThisDrawing.Blocks If objBlock.name = lstDestination.List(i) Then Set objBlock = ThisDrawing.Blocks.Item(Me.lstDestination.List(i)) For Each oEnt In objBlock If TypeOf oEnt Is AcadAttribute Then Set AttObj = oEnt If AttObj.TagString = "TYPE" Then If AttObj.TextString = TxtOldTagName Then Value = TxtNewTagName AttObj.Update Debug.Print AttObj.TagString Debug.Print Tag Debug.Print Value End If End If End If Next oEnt End If Next objBlock Next i End Function Quote
Lee Mac Posted January 10, 2009 Posted January 10, 2009 In LISP, it would be something like this: (defun c:tagchng (/ nTag oTag ss ssl bCnt bEnt aEnt aEntlist) (while (or (not nTag) (not oTag) ) ;_ end or (setq oTag (getstring "\nReplace: ") nTag (getstring "\nWith: ") ) ;_ end setq ) ;_ end while (if (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 410 (getvar "ctab"))))) (progn (setq ssl (1- (sslength ss)) bCnt 0 ) ;_ end setq (while (not (minusp ssl)) (setq bEnt (ssname ss ssl)) (if (setq aEnt (entnext bEnt)) (progn (setq aEntlist (entget aEnt)) (if (= (cdr (assoc 2 aEntlist)) oTag) (progn (setq aEntlist (subst (cons 2 nTag) (assoc 2 aEntlist) aEntlist)) (entmod aEntlist) (setq bCnt (1+ bCnt)) ) ;_ end progn ) ;_ end if ) ;_ end progn ) ;_ end if (setq ssl (1- ssl)) ) ;_ end while ) ;_ end progn (princ "\n<!> No Blocks Found <!>") ) ;_ end if (princ (strcat "\n" (rtos bCnt 2 0) " Block Attribute Tags Modified.")) (princ) ) ;_ end defun Quote
Raggi_Thor Posted January 10, 2009 Posted January 10, 2009 In VBA you must look at the BlockReferences in ModelSpace (or PaperSpace). Attributes are a bit special, they are not updated in the references when you change the block definition. Something like For each obj in thisdraing.modelspace and If obj.entityname = acdbblockreference then Set varAtts = obj.GetAttributes Quote
Lee Mac Posted January 10, 2009 Posted January 10, 2009 With numerous replacements: (defun c:tagchng (/ nTag oTag AssLst TagLst ss ssl bCnt bEnt aEnt aEntlist) (while (or (not nTag) (/= nTag "") (not oTag) (/= oTag "") ) ;_ end or (setq oTag (getstring "\nReplace: ") nTag (getstring "\nWith: ") ) ;_ end setq (setq AssLst (list oTag nTag)) (setq TagLst (cons AssLst TagLst) ) ;_ end setq ) ;_ end while (setq TagLst (cdr TagLst)) (if (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 410 (getvar "ctab"))))) (progn (setq bCnt 0) (foreach tag TagLst (setq ssl (1- (sslength ss))) (while (not (minusp ssl)) (setq bEnt (ssname ss ssl)) (if (setq aEnt (entnext bEnt)) (progn (setq aEntlist (entget aEnt)) (if (= (cdr (assoc 2 aEntlist)) (car tag)) (progn (setq aEntlist (subst (cons 2 (cadr tag)) (assoc 2 aEntlist) aEntlist)) (entmod aEntlist) (setq bCnt (1+ bCnt)) ) ;_ end progn ) ;_ end if ) ;_ end progn ) ;_ end if (setq ssl (1- ssl)) ) ;_ end while ) ;_ end foreach ) ;_ end progn (princ "\n<!> No Blocks Found <!>") ) ;_ end if (princ (strcat "\n" (rtos bCnt 2 0) " Block Attribute Tags Modified.")) (princ) ) ;_ end defun Quote
David Bethel Posted January 11, 2009 Posted January 11, 2009 Dave, I'm assuming from the thread's title that you want to change the INSERT ATTRIBute string values, not the BLOCK ATTDEF Tag names. They are 2 very different things. I guessed that the old string value is not case sensitive and that spaces are allowed. And that empty strings as acceptable. Also that the new value's string case will be inputted correctly. [b][color=BLACK]([/color][/b]defun c:chg-att [b][color=FUCHSIA]([/color][/b]/ ov nv ss i en an ad[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not ov[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq ov [b][color=MAROON]([/color][/b]getstring t [color=#2f4f4f]"\nOld ATTRIB Value: "[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not nv[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq nv [b][color=MAROON]([/color][/b]getstring t [color=#2f4f4f]"\nNew ATTRIB Value: "[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"INSERT"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 66 1[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]if [b][color=RED]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 410 [b][color=PURPLE]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 67 [b][color=PURPLE]([/color][/b]- 1 [b][color=TEAL]([/color][/b]getvar [color=#2f4f4f]"TILEMODE"[/color][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq i [b][color=MAROON]([/color][/b]sslength ss[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]minusp [b][color=BLUE]([/color][/b]setq i [b][color=RED]([/color][/b]1- i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b] an [b][color=GREEN]([/color][/b]entnext en[b][color=GREEN])[/color][/b] ad [b][color=GREEN]([/color][/b]entget an[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]while [b][color=GREEN]([/color][/b]/= [color=#2f4f4f]"SEQEND"[/color] [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 0 ad[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]and [b][color=BLUE]([/color][/b]= [b][color=RED]([/color][/b]strcase ov[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]strcase [b][color=PURPLE]([/color][/b]cdr [b][color=TEAL]([/color][/b]assoc 1 ad[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]entmod [b][color=RED]([/color][/b]subst [b][color=PURPLE]([/color][/b]cons 1 nv[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]assoc 1 ad[b][color=PURPLE])[/color][/b] ad[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]entupd en[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]setq an [b][color=BLUE]([/color][/b]entnext an[b][color=BLUE])[/color][/b] ad [b][color=BLUE]([/color][/b]entget an[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
Lee Mac Posted January 11, 2009 Posted January 11, 2009 What is the "SEQEND" David?, Also, why set TILEMODE as a restriction? To be honest, I did wonder why he wanted to change Attribute Definition Values, but followed his request and created the LISP, but I think Attribute String values is more likely. Quote
David Bethel Posted January 11, 2009 Posted January 11, 2009 A SEQEND is the last entity in an ATTRIButed INSERT or a HEAVYweight ( old style ) POLYLINE. It tells you when you are done with the sequential entities. CTAB was introduced in AutoCAD 2000. Before that we only had modelspace/paperspace entities ( dxf group 67 ). -David Quote
Lee Mac Posted January 11, 2009 Posted January 11, 2009 Ahh, I understand it now: so, you are accounting for every version of ACAD - nice. Quote
Lee Mac Posted January 11, 2009 Posted January 11, 2009 This same task could just be accomplished using the Find and Replace tool in ACAD. (If indeed it is the Attribute String values that need changing and not the Attribute Tag Definitions...) Quote
Raggi_Thor Posted January 11, 2009 Posted January 11, 2009 I knew I had seen this problem before This is what I did for a customer a few months ago! My memory is good, but short.. Getting all tags: Private Sub ddGetAllTags() Dim att As AcadAttributeReference Dim atts As Variant Dim blk As AcadBlockReference Dim obj As AcadEntity Dim i As Integer, j As Integer tags = "" For Each obj In ActiveDocument.ModelSpace If obj.EntityName = "AcDbBlockReference" Then Set blk = obj If blk.HasAttributes Then atts = blk.GetAttributes For i = LBound(atts) To UBound(atts) Set att = atts(i) If InStr(tags, att.TagString) = 0 Then tags = tags & "TAG:" & att.TagString & vbCr ReDim Preserve MyArray(j) As String MyArray(j) = att.TagString 'Debug.Print j & " : " & att.TagString j = j + 1 End If Next i End If End If Next End Sub Renaming them, according to text in dialog box (see image): Private Sub ddRenameAllTags() Dim i As Integer For i = 0 To UBound(MyArray) 'If Len(Controls(MyArray(i)).Value) > 0 Then 'Debug.Print i & " : " & MyArray(i) & " -> " & Controls(MyArray(i)).Value tags = tags & "TAG:" & Controls(MyArray(i)).Name & "," If InStr(Controls(MyArray(i)), " ") > 0 Then MsgBox "Tags may not contain spaces.", vbCritical, MyApp Controls(MyArray(i)).SetFocus 'Controls(MyArray(i)).SelectAll Exit Sub End If If Me.chkSave Then SaveSetting MyApp, MySec, Controls(MyArray(i)).Name, Controls(MyArray(i)) End If 'End If Next i If Len(tags) > 0 Then Dim att As AcadAttributeReference Dim atts As Variant Dim blk As AcadBlockReference Dim obj As AcadEntity For Each obj In ActiveDocument.ModelSpace If obj.EntityName = "AcDbBlockReference" Then Set blk = obj If blk.HasAttributes Then atts = blk.GetAttributes For i = LBound(atts) To UBound(atts) Set att = atts(i) If InStr(tags, "TAG:" & att.TagString) > 0 Then If Len(Controls(att.TagString).Value) > 0 Then att.TagString = (Controls(att.TagString).Value) End If End If Next i End If End If Next End If End 'close dialog End Sub ddRenameTags (2).zip Quote
Lee Mac Posted January 11, 2009 Posted January 11, 2009 Raggi, what is a dvb file and how do you make them? Quote
Raggi_Thor Posted January 11, 2009 Posted January 11, 2009 It's a Visual BAsic file for AutoCAD, Visual Basic for Applications, VBA. Use APPLOAD or VBALOAD to load it. Use VBARUN to acticate the macro. I normaly use a mnu file to make a menu and a mnl file (menu lisp) that is loaded automatically with the manu, and in there I put some lips to define the command: (defun ddRenameTags() (command) (command "-vbarun" "ddRenameTags.dvb!ddRenameTags") (princ) ) ;Add aliases as you like: (defun c:rent() (ddRenameTags) ) (defun c:rt() (ddRenameTags) ) (defun c:RenameTags() (ddRenameTags) ) The line (command "-vbarun" "ddRenameTags.dvb!ddRenameTags") will load the dvb file and activate the macro (sub). Quote
Raggi_Thor Posted January 11, 2009 Posted January 11, 2009 And good night to you A few minutes past midnight here, work tomorrow.. Quote
Raggi_Thor Posted January 11, 2009 Posted January 11, 2009 Forgot, how do you make them Menues in ac2009? No Idea! Command: VBAIDE takes you to the VBA editor. Shortcut: Alt + F11 Quote
Lee Mac Posted January 11, 2009 Posted January 11, 2009 Forgot, how do you make them Menues in ac2009? No Idea! Command: VBAIDE takes you to the VBA editor. Shortcut: Alt + F11 Excellent Thanks! 11:30pm here, I probably should be in bed too - got a 9am lecture tomorrow! Quote
khiraly Posted April 6, 2009 Posted April 6, 2009 Hi there! I need to rename lot of blocks' attributes sequentially. So I have blocks, where the attribute name is 1, 2, 3, 3, 3, 4. I would like to rename it, by selecting the blocks what I want exactly to rename and type the start value and the incremental value. Like: start value: 3 incremental: 2 The result should be: 3, 5, 7, 9, 11, 13 The bonus would be if it could increment the numbers inside a text. Like F1, F2, F3, F3, F3, F4 ->F1, F2, F3, F4, F5, F6 Do somebody already faced such a problem? Thank you in advance. Nevermind, I found the right thread which solves my problem. Such a knowledgable forum. Really helpful by the way. Here is the script's homepage: http://www.asmitools.com/Files/Lisps/Renum.html With video tutorial, impressive as hell. Foolproof;) Quote
Lee Mac Posted April 6, 2009 Posted April 6, 2009 Hi there! I need to rename lot of blocks' attributes sequentially. So I have blocks, where the attribute name is 1, 2, 3, 3, 3, 4. I would like to rename it, by selecting the blocks what I want exactly to rename and type the start value and the incremental value. Like: start value: 3 incremental: 2 The result should be: 3, 5, 7, 9, 11, 13 The bonus would be if it could increment the numbers inside a text. Like F1, F2, F3, F3, F3, F4 ->F1, F2, F3, F4, F5, F6 Do somebody already faced such a problem? Thank you in advance. Nevermind, I found the right thread which solves my problem. Such a knowledgable forum. Really helpful by the way. Here is the script's homepage: http://www.asmitools.com/Files/Lisps/Renum.html With video tutorial, impressive as hell. Foolproof;) Can't go wrong with ASMI Quote
