Dynamic dynamic block
gegenytibor
Hi all,
I have 4 dynamic blocks and each has 4 different visibility states.
I would like to create a dynamic block which contains the previous 4 dynamic blocks and where I can set the different blocks different visibility states (like the drop down menu).
Is it possible somehow?
Or should I make all of the possibilities visibility states?
Please help if you can!
Thank you!
  • 2 months later...
From what I can see, making 16 visibilities in a block with each single visibility in the nested block should work.
Maybe it can be done easier, but this is the workaround I always use.
What you want is only possible with vis-add-eng lisp files (and AutoCAD 2007?). I would just follow dirks recommendation for simplicity sake.
