I'm in a dynamic view in model space 35, -135, distance 60". When I bring it into Layout 1 it comes in as the top view. In the previous drawing when I toggled between model and paper everything was fine. Did I inadvertently hit a key or somehow change a setting?
HELP!
Thanks,
The view in PS viewport can be of any view. Changing the dview in MS is only for MS layout. If you create a new PS viewport it should show the same as MS. Is that what you are seeing?
If not, simply change the dview through the PS viewport rather than MS.
I just noticed you have 2012, I have 2017 so it may work differently now.
No, I'm working in 2017. just haven't updated my profile. I guess what I meant, you can't use DV in a layout. I've tried doing it with a few similar models and it seems to be working OK. Maybe that model had some sort of glitch?
Thanks,
Edited by herguth1
spelling
To use DView you have to be in model space. Now you can be in a layout but activate a viewport THEN use DView. That does work.
