raj banerjee
Drawing a column in MEP
raj banerjee
can anyone help, on the arictect toolpalette, I want to draw some columns, I have the dimensions for the column but when I draw them they appear as a squar box instad of the 'I' beam shape. Can any one offer some advice on this please?
thanks very much
Share this post
Link to post
LifeoRiley0
Format>Structural Members>Wizard Then select the item, I beam, Tube steel etc. Fill out the dimensions and the name it. Go to the Design pulldown Structural Members> Add Column. Then in Properties select the named item and draw.
Hope this helps.
Share this post
Link to post
raj banerjee
Solved, thanks you very much !!!!
cheers
Share this post
Link to post
LifeoRiley0
You are quite welcome...
Share this post
Link to post
