add or subract for drywall when measuring to rough framing
Nick, I took a closer look at your changes and I'm wondering if they would work the way you have them shown here. The INITGET entries need to match the GETKWORD entries. The "1" will work, but not the 2,3 or 4. You can just change them to match, as well as in the COND statement. See the red entries below:
(defun c:t (/ chg mod num en1 ed)
(princ "\nEnter Drywall Thickness:   1=+1/2\", 2=-1/2\", 3=+5/8\", 4=-5/8\"")
(initget "[color=red]1 2 3 4[/color]")
(setq chg (getkword "\nEnter Drywall Thickness < 1/2/3/4 > : "))
;;(princ "\nOne Drywall Thickness or Two?")
;;(initget "1 2")
;;(setq thk (getreal "\nOne Drywall Thickness or Two: < 1 / 2 > : "))
(cond
 ((= chg "[color=red]1[/color]") (setq mod 0.5))
 ((= chg "[color=red]2[/color]") (setq mod -0.5))
 ((= chg "[color=red]3[/color]") (setq mod 0.625))
 ((= chg "[color=red]4[/color]") (setq mod -0.625))
 (t nil)
;;(setq mod (* thk mod))
(command "dimlinear" pause pause pause)
(command)
(setq num (+ mod (cdr (assoc 42 (entget (entlast))))))
(setq num (strcat "(" (rtos num 4 3) ")"))
(setq en1 (entlast))
(setq ed (entget en1))
(setq ed (subst (cons 1 num) (assoc 1 ed) ed))
(entmod ed)
  • Replies 22
  • BKT
    10
  • nickbs
    10
  • SLW210
    1
  • Dadgad
    1
BKT thanks for showing me that. I think that I would of figured it out. and you were right 1 did work but 234 didn't.,
Have a good weekend,, PEace Nick 8)
Just a subtle way of not doing the same thing twice, entlast. Other suggestion would be a dcl with radio buttons version 2.
(setq num (+ mod (cdr (assoc 42 (setq ed (entget (entlast)))))))
(entmod ed)
