Once upon a time I had a lsp routine called "untwist". Once a drawing was dview twisted (or having used the "twist" lsp) this "untwist" would rotate back to 0 and set the snapang to 0 as well!
I miss it.
Can anyone help me out. It's been so long now.
I miss it.
All you need to do is use the plan world command and reset the snapang and angbase. You can also make sure to set the zoom the same by checking the variables viewsize and viewctr.
(if (not (= 1 (getvar 'cvport)))(command "._plan" "_w"))
 (setvar 'snapang 0)
 (setvar 'angbase 0)
 (setvar 'snapang 0)
 (setvar 'angbase 0)
Thanks for the reply. I am not fluent in LISP. Okay, I do not speak LISP at all! There's the confession.
Is your code actually the lisp that I can use? Or is that a few ideas to go by?
I was spoiled by having that lisp at one time. Wish I had put it in my pocket for later use.
Much appreciated.
Quickly written and untested:
(defun c:plan2 (/ *error* ctr ht)
 (defun *error* (msg)
   (LM:endundo (LM:acdoc))
   (if (not
         (member msg '("Function cancelled" "quit / exit abort"))
 (if (> (getvar 'cvport) 1)
     (LM:startundo (LM:acdoc))
     (command "._ucs" "_w")
     (setq ctr (getvar 'viewctr)
           ht  (getvar 'viewsize)
     (command "._plan" "_W")
     (setvar 'snapang 0)
     (setvar 'angbase 0)
     (command "zoom" "c" ctr ht)
;;;Created by Lee Mac
(defun LM:startundo (doc)
 (LM:endundo doc)
 (vla-startundomark doc)
(defun LM:endundo (doc)
 (while (= 8 (logand 8 (getvar 'undoctl)))
   (vla-endundomark doc)
(defun LM:acdoc nil
 (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
 (LM:acdoc)
Well, you are the king! It works. I could never had done that.
Many, many thanks.
How about a simple macro?
^C^C_dview;all;;tw;0;^P(progn(setvar "snapang" 0)(princ))
