Greeting!
Just checking with you all whether the AutoCAD 2009 does it have any animation feature or not. Previously I using my 3DS MAX for doing animation by a camera going around and setting the time film.
Example: I set the camera from point A to point B will take me 30 seconds.
So... May i know in AutoCAD 2008 or 2009 got this feature?
Thanks for viewing my post.
Best Regards,
Gin
Also look at the anipath command... it allows you to plot a path (along all sorts of entities with a specified point or path as a target) & define the frame rate & number of frames/duration to create avi's, wmv's or mpegs of a static model.
Thanks for the reply. I will go check it out tonight.
Okie! I have tried it out. It's some sort of thing i wanted but still not the best I'm expected from AutoCAD2009. >
Anyway, may I know did someone know how to export the AutoCAD dwg file to walk through file? I had forgotten what the plug-in/format names. It was something like I create a house and I can walk around the house and viewing as I like. The only thing I remember is I can view this model from Internet Explorer.
I'm really sorry that I create so much difficulity. And ReMark & Hedgehog I'm really appreciate your help. Thanks a lot.
Are you talking about a 3D DWF file?
Not this too.. >
But I remember that plug-in can make you like you are in the house walking around even you can walk on the staircase (Not go through) It's not like what we using now even can go through the wall.
I think I just found clue.. it's was export to .w3d format but I cant remember how to export and where to download the plug-in cause last time I'm was follow the tutorial and to their website.
