Kevin Malone Posted April 24, 2017 Share Posted April 24, 2017 Hello, I have georeferenced raster, but it has margins that shouldn't be there. I have tried to remove them using IMAGECLIP, but as I understand this command just hides portion of the raster outside/inside of the boundary. Is there any way to trim image in AutoCAD? I'm using C3D 2012 with Raster Design. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 24, 2017 Share Posted April 24, 2017 As far as I know, there is no way to trim images in Autocad. You will need to use an image editing program like Photoshop if you want to do that, unless there is a tool within Raster Design that can do it? I don't use Raster Design so I wouldn't know. Why can't you just use Imageclip and hide the margins? Quote Link to comment Share on other sites More sharing options...
Kevin Malone Posted April 24, 2017 Author Share Posted April 24, 2017 Thank you for reply. I've been searching for command in Raster Design that can do this, but couldn't find any, and everyone suggest using PS, GIMP... I must say I'm surprised this function doesn't exist in Raster Design already. This raster is part of bigger raster mosaic, so hiding doesn't do the job. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 24, 2017 Share Posted April 24, 2017 I got this info from for Raster Design, though I haven't used it, I prefer GIMP or Photoshop myself. You can use Raster Design tool to clip or crop raster image. Given that the image is inserted via IINSERT command. 1.From Raster Tools ribbon select Crop option (i.e. Rectangular Region) 2.Specify first point and angle (i.e. 0) 3.Specify second point and click to complete command 4.Save the drawing P.S. I moved your thread to the Civil 3D & LDD Forum. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 25, 2017 Share Posted April 25, 2017 Have you tried using 2 layout mviews make 1 a clip shape for the raster the second your model view. If its rectangular "Paint" will clip then re-save, you may lose your georeferencing though. Quote Link to comment Share on other sites More sharing options...
