Familiar with new windows 10 crashes, please verify that your auto save was not altered .
A simple check will often prevent costly rework.
Been there so many times when windows freaks out the save option is changed.
Just a reminder to back check will often save user a lot of aggravation.
Enjoy
Best,
Robert
I watched a Lynne Allen Utube the other day, from Cadalyst and it was about improving auto save times, you can change also the % save value mine was set to 0 now I run 75%. I will see how much difference it makes.
Why and how does a Windows crash change the auto save option?
Why are you experiencing so many crashes?
I have not had a single Windows 10 crash.
Autosave timer restarts every time you manually Save the drawing, which you should do often.
I don't use AutoCAD on Windows 10, but I cannot recall my Windows 10 ever crashing, either.
Also using Windows 10 X64 No problems here either.
