After inserting an OLE object onto my drawing (paper space), it does not plot correctly. The OLE object is an Excel spreadsheet and only half of it is plotted. However, I am able to plot the drawing successfully on another computer workstation. Could the issue be with my computer's settings?
Yes there is problem. But you can symply Ctr+C in MS Excel and Ctr+V in AutoCAD. All cells will visible and worksheet will inserted as OLE object.
I used paste special and linked the excel file to my drawing. On the contrary, all the cells were not visible. I can't figure out the problem.
IIRC Excel is limited to a certain number of lines that you can do that with. Word has its limitations to. There are purchasable solutions for this issue
What is IIRC? I was searching through the plot & publish tab under the options mens. What does the following mean? "Use OLE application when plotting OLE objects." If I checked this box, how will my drawing be affected?
Sorry...
IIRC is "if I remember correctly".
Let me see if I can find the software you need. I'll be back
http://www.cadtool.net/
It's an issue you won't be able to fix to your satisfaction unless you spend money on a package like the one above. I really think it is limited to a certain number of lines, so do the top of the page, then do the bottom, or something like that
  • 1 year later...
I would like to bring back this thread. I have an OLE image of a aerial land survey that I am laying under the basemap that was drawn. When I plot it on an actual printer, everything shows up fine, but when I try to plot to PDF, many of the lines of the actual drawing vanish as well as the OLE object.
I need to know how to print the drawing with the OLE object visible and without messing up the rest of the drawing to PDF files.
Thanks for your help!
