Ravenstown
Edit in Section- command option missing
Ravenstown
Have been using Autocad MEP 2013 which when you right click the General Panel contains 'isolate objects' option with the 'edit in section' sub option
Just downloaded Autocad MEP 2018 which when you right click the General Panel contains 'isolate' option, and does not have the 'edit in section', 'edit in elevation' or edit in plan' sub options
The help section for 'Edit objects in a temporary section view' is described the same in 2013 and 2018
Does the General list have options on what is shown?
Is there a different path in 2018 to this command?
Share this post
Link to post
