kbattist Posted January 13, 2009 Posted January 13, 2009 Hello, could someone please help me with adding color to a drawing. I have a drawing of an office floor plan. On one floor, there are 5 different branches. I want to designate a color for each branch. How can I add color to each room on my floor plan? Quote
Attila The Gel Posted January 13, 2009 Posted January 13, 2009 Welcome to this forum kbattist! I usualy make a boundery with pline "pl" and than hatch that area in any color I desire. MAke sure you do this in a new layer so you can turn it off if you want to draw anything els on the floorplans. Quote
Attila The Gel Posted January 13, 2009 Posted January 13, 2009 I don't like solid colors on floorplans unless its realy nessesary. otherwise i chose hatch 31 with a thight hatchscale. Quote
kbattist Posted January 13, 2009 Author Posted January 13, 2009 Can you please break it down into easy steps? I only know the basics with this program. Quote
Attila The Gel Posted January 13, 2009 Posted January 13, 2009 Well heres a step by step. 1, open a new drawing to test! 2, type 'pl' to create a polyline then enter so you can start. 3, make a random figure (square) and when your done type "c" to close it 4, now type "hatch" and enter. the hacth option will start up. 5. Take a look at all the optios here, normaly you can figure it out. Quote
BIGAL Posted January 14, 2009 Posted January 14, 2009 Bit more if you use solid as the hatch pattern pick light colours. Also under Tools Draw order send to back, if you want line work to appear on top. Quote
f700es Posted January 14, 2009 Posted January 14, 2009 I usually use a solid hatch and as Bigal says I move my to the back with the DrawOrder command. Quote
Attila The Gel Posted January 14, 2009 Posted January 14, 2009 No problem! Glad we could help you and dont forget the answers are waiting for you on this forum! Good luck! Quote
