aawilds Posted June 13, 2017 Share Posted June 13, 2017 My boss may have just asked for the impossible, but he wants a lisp to be able to window select multiple text then window select lines near the text, and have the text align to the line or polyline that is closest to the text. I have something that allows me to pick a line then a text, but I have no idea how to do this. Any help is greatly appreciated, this is way above my ability. The attached pictures show before and after. Quote Link to comment Share on other sites More sharing options...
rkent Posted June 13, 2017 Share Posted June 13, 2017 This is probably what you need. Â http://www.lee-mac.com/curvealignedtext.html 1 Quote Link to comment Share on other sites More sharing options...
aawilds Posted June 13, 2017 Author Share Posted June 13, 2017 I had looked at that Lisp by Lee mac. It is good, but I need to be able to select multiple text that are already in the drawing, and them be aligned to the nearest line. Without having to pick individually. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted June 13, 2017 Share Posted June 13, 2017 I had looked at that Lisp by Lee mac. It is good, but I need to be able to select multiple text that are already in the drawing, and them be aligned to the nearest line. Without having to pick individually. Give this a try: (defun c:foo (/ a l lines p ss text) (if (setq ss (ssget '((0 . "Line,Text")))) (progn (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (if (= "TEXT" (cdr (assoc 0 (entget x)))) (setq text (cons x text)) (setq lines (cons x lines)) ) ) (if lines (foreach x text (setq p (cdr (assoc 10 (entget x)))) (setq l (car (vl-sort lines '(lambda (a b) (< (distance p (vlax-curve-getclosestpointto a p)) (distance p (vlax-curve-getclosestpointto b p)) ) ) ) ) ) (setq a (angle (cdr (assoc 10 (entget l))) (cdr (assoc 11 (entget l))))) (entmod (subst (cons 50 a) (assoc 50 (entget x)) (entget x))) ) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
aawilds Posted June 13, 2017 Author Share Posted June 13, 2017 That works for the most part. Is there any way to get it to work with polylines? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 14, 2017 Share Posted June 14, 2017 The answer for plines is you can get closest point to and then do a "first derivative" which will allow you to work out an angle for the text. look at this bit of code. Â (defun alg-ang (obj pnt) (angle '(0. 0. 0.) (vlax-curve-getfirstderiv obj (vlax-curve-getparamatpoint obj pnt ) ) ) ) Quote Link to comment Share on other sites More sharing options...
ronjonp Posted June 14, 2017 Share Posted June 14, 2017 That works for the most part. Is there any way to get it to work with polylines? It's very easy to include polylines, but your initial question only asked for lines and text. With the code provided, just explode polylines and it should work per the initial request. Quote Link to comment Share on other sites More sharing options...
aawilds Posted June 14, 2017 Author Share Posted June 14, 2017 Thank You ronjonp and BIGAL. You both have been very helpful. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted June 14, 2017 Share Posted June 14, 2017 Here's a version that will work with polylines too: (defun c:foo (/ _aap l lines p p2 ss text) ;; RJP - 6.14.2017 (defun _aap (ename pt / param) (if (and (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getendparam (list ename)))) (setq param (vlax-curve-getparamatpoint ename pt)) ) (angle '(0 0) (vlax-curve-getfirstderiv ename param)) ) ) (if (setq ss (ssget '((0 . "*polyline,Line,Text")))) (progn (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (if (= "TEXT" (cdr (assoc 0 (entget x)))) (setq text (cons x text)) (setq lines (cons x lines)) ) ) (if lines (foreach x text (setq p (cdr (assoc 10 (entget x)))) (setq l (mapcar '(lambda (x) (list (setq p2 (vlax-curve-getclosestpointto x p)) (distance p p2) (_aap x p2)) ) lines ) ) (setq l (car (vl-sort l '(lambda (a b) (< (cadr a) (cadr b)))))) (entmod (subst (cons 50 (caddr l)) (assoc 50 (entget x)) (entget x))) ) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
Least Posted June 16, 2017 Share Posted June 16, 2017 That's really good Ron thanks. I was wondering how to make the text readable? I cant see how to simply integrate Alans routine in to yours http://cadtips.cadalyst.com/multiline-text/make-text-readable any ideas? Â Thanks P Quote Link to comment Share on other sites More sharing options...
ronjonp Posted June 16, 2017 Share Posted June 16, 2017 That's really good Ron thanks. I was wondering how to make the text readable? I cant see how to simply integrate Alans routine in to yours http://cadtips.cadalyst.com/multiline-text/make-text-readableany ideas? Â Thanks P There are a ton of makereadable functions HERE. Just apply one of them to this part of the line here in red: (entmod (subst (cons 50 (caddr l)) (assoc 50 (entget x)) (entget x))) Quote Link to comment Share on other sites More sharing options...
ktbjx Posted August 6, 2019 Share Posted August 6, 2019 (edited) On 6/14/2017 at 2:56 AM, ronjonp said: Give this a try: Â (defun c:foo (/ a l lines p ss text) (if (setq ss (ssget '((0 . "Line,Text")))) (progn (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (if (= "TEXT" (cdr (assoc 0 (entget x)))) (setq text (cons x text)) (setq lines (cons x lines)) ) ) (if lines (foreach x text (setq p (cdr (assoc 10 (entget x)))) (setq l (car (vl-sort lines '(lambda (a b) (< (distance p (vlax-curve-getclosestpointto a p)) (distance p (vlax-curve-getclosestpointto b p)) ) ) ) ) ) (setq a (angle (cdr (assoc 10 (entget l))) (cdr (assoc 11 (entget l))))) (entmod (subst (cons 50 a) (assoc 50 (entget x)) (entget x))) ) ) ) ) (princ) ) Â Â i found this just what i need. but can someone add alingment of the text to the midpoint of the line? all the text are in justify middle center. and i need the texts to be in midpoints of the lines i mean my texts are in above and some are below the line, i want the text alinged as well to the mid point of the line Edited August 6, 2019 by ktbjx Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 6, 2019 Share Posted August 6, 2019 Give this a try: (defun c:foo (/ a l lines mp p p1 p2 ss text) (if (setq ss (ssget ":L" '((0 . "Line,Text")))) (progn (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (if (= "TEXT" (cdr (assoc 0 (entget x)))) (setq text (cons x text)) (setq lines (cons x lines)) ) ) (if lines (foreach x text (setq p (cdr (assoc 10 (entget x)))) (setq l (car (vl-sort lines '(lambda (a b) (< (distance p (vlax-curve-getclosestpointto a p)) (distance p (vlax-curve-getclosestpointto b p)) ) ) ) ) ) (setq p1 (cdr (assoc 10 (entget l)))) (setq p2 (cdr (assoc 11 (entget l)))) (setq mp (polar p1 (setq a (angle p1 p2)) (/ (distance p1 p2) 2))) (entmod (subst (cons 50 a) (assoc 50 (entget x)) (entget x))) (entmod (subst (cons 10 mp) (assoc 10 (entget x)) (entget x))) (entmod (subst (cons 11 mp) (assoc 11 (entget x)) (entget x))) ) ) ) ) (princ) ) Â Quote Link to comment Share on other sites More sharing options...
ktbjx Posted August 7, 2019 Share Posted August 7, 2019 9 hours ago, ronjonp said: Give this a try: (defun c:foo (/ a l lines mp p p1 p2 ss text) (if (setq ss (ssget ":L" '((0 . "Line,Text")))) (progn (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (if (= "TEXT" (cdr (assoc 0 (entget x)))) (setq text (cons x text)) (setq lines (cons x lines)) ) ) (if lines (foreach x text (setq p (cdr (assoc 10 (entget x)))) (setq l (car (vl-sort lines '(lambda (a b) (< (distance p (vlax-curve-getclosestpointto a p)) (distance p (vlax-curve-getclosestpointto b p)) ) ) ) ) ) (setq p1 (cdr (assoc 10 (entget l)))) (setq p2 (cdr (assoc 11 (entget l)))) (setq mp (polar p1 (setq a (angle p1 p2)) (/ (distance p1 p2) 2))) (entmod (subst (cons 50 a) (assoc 50 (entget x)) (entget x))) (entmod (subst (cons 10 mp) (assoc 10 (entget x)) (entget x))) (entmod (subst (cons 11 mp) (assoc 11 (entget x)) (entget x))) ) ) ) ) (princ) ) Â Sir, the text went do the midpoint of the line... i just want the center point of the text to be aligned with the midpoint of the line. like this: Drawing1.dwg Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 7, 2019 Share Posted August 7, 2019 Try this. In the future post a drawing with your question first so the translation does not get lost. (defun c:foo (/ a h l lines mp p p1 p2 p3 p4 pa s text) ;; RJP » 2019-08-07 (if (setq s (ssget ":L" '((0 . "Line,Text")))) (progn (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (if (= "TEXT" (cdr (assoc 0 (entget x)))) (setq text (cons x text)) (setq lines (cons x lines)) ) ) (if lines (foreach x text (setq p (cdr (assoc 11 (entget x)))) (setq l (car (vl-sort lines '(lambda (a b) (< (distance p (vlax-curve-getclosestpointto a p)) (distance p (vlax-curve-getclosestpointto b p)) ) ) ) ) ) (setq h (* 0.75 (cdr (assoc 40 (entget x))))) (setq p1 (cdr (assoc 10 (entget l)))) (setq p2 (cdr (assoc 11 (entget l)))) (setq mp (polar p1 (setq a (angle p1 p2)) (/ (distance p1 p2) 2))) (setq p3 (polar mp (setq pa (+ (/ pi 2) a)) h)) (setq p4 (polar mp (+ pi pa) h)) (if (< (distance p p4) (distance p p3)) (setq p3 p4) ) (entmod (subst (cons 50 a) (assoc 50 (entget x)) (entget x))) (entmod (subst (cons 10 p3) (assoc 10 (entget x)) (entget x))) (entmod (subst (cons 11 p3) (assoc 11 (entget x)) (entget x))) ) ) ) ) (princ) )  Quote Link to comment Share on other sites More sharing options...
rog1n Posted August 8, 2019 Share Posted August 8, 2019 Hello, Ranjani if it's not too much to ask, is it possible to modify the lisp to work with closed polylines and the text aligned with the middle lines inside of the formed draw? Â example.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 9, 2019 Share Posted August 9, 2019 The better way is to draw the pline and label at that time. If its lengths etc. label inside outside. I don't have anything. This is a built in function of CIV3D. 1 Quote Link to comment Share on other sites More sharing options...
rog1n Posted August 14, 2019 Share Posted August 14, 2019 On 8/7/2019 at 11:20 AM, ronjonp said: Try this. In the future post a drawing with your question first so the translation does not get lost. (defun c:foo (/ a h l lines mp p p1 p2 p3 p4 pa s text) ;; RJP » 2019-08-07 (if (setq s (ssget ":L" '((0 . "Line,Text")))) (progn (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (if (= "TEXT" (cdr (assoc 0 (entget x)))) (setq text (cons x text)) (setq lines (cons x lines)) ) ) (if lines (foreach x text (setq p (cdr (assoc 11 (entget x)))) (setq l (car (vl-sort lines '(lambda (a b) (< (distance p (vlax-curve-getclosestpointto a p)) (distance p (vlax-curve-getclosestpointto b p)) ) ) ) ) ) (setq h (* 0.75 (cdr (assoc 40 (entget x))))) (setq p1 (cdr (assoc 10 (entget l)))) (setq p2 (cdr (assoc 11 (entget l)))) (setq mp (polar p1 (setq a (angle p1 p2)) (/ (distance p1 p2) 2))) (setq p3 (polar mp (setq pa (+ (/ pi 2) a)) h)) (setq p4 (polar mp (+ pi pa) h)) (if (< (distance p p4) (distance p p3)) (setq p3 p4) ) (entmod (subst (cons 50 a) (assoc 50 (entget x)) (entget x))) (entmod (subst (cons 10 p3) (assoc 10 (entget x)) (entget x))) (entmod (subst (cons 11 p3) (assoc 11 (entget x)) (entget x))) ) ) ) ) (princ) )   Is possible change to work with polyline too? Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 14, 2019 Share Posted August 14, 2019 (edited) 3 minutes ago, rog1n said:  Is possible change to work with polyline too? Is it possible to get a thank you first ? Edited August 14, 2019 by ronjonp 1 1 Quote Link to comment Share on other sites More sharing options...
rog1n Posted August 14, 2019 Share Posted August 14, 2019 2 minutes ago, ronjonp said: Is it possible to get a thank you first ?  sorry I had never noticed this option Quote Link to comment Share on other sites More sharing options...
