broncos15
Change text color for multileader
broncos15
So I am trying to have the ability to change the text color of mulitleaders from bylayer to red (it is part of a QC routine). After looking through all the properties, the only way I can figure out how to do it is by doing a workaround where I basically just copy and paste the text back into the multileader.
(vla-put-TextString obj (strcat "{\\C" (itoa txtcol) ";" txtstring "}"))
The issue is that this will override if there are any fields within the text. Is there some other workaround that I am not thinking of?
Share this post
Link to post
Lee Mac
You could change the TextColor property of the corresponding MLeader Style, e.g.:
(defun c:test ( / aci col sel sty )
   (if (and (setq sel (ssget "_+.:E:S" '((0 . "MULTILEADER")))) (setq aci (acad_colordlg 1 nil)))
           (setq sty
               (vla-item
                   (vla-item
                       (vla-get-dictionaries
                           (vla-get-activedocument
                               (vlax-get-acad-object)
                       "acad_mleaderstyle"
                   (vla-get-stylename (vlax-ename->vla-object (ssname sel 0)))
               col (vla-get-textcolor sty)
           (vla-put-colorindex col aci)
           (vla-put-textcolor  sty col)
(vl-load-com) (princ)
Note that this will affect all MLeaders referencing the Style however.
Share this post
Link to post
Grrr
I like your suggestion. :thumbsup:
Share this post
Link to post
broncos15
Lee thank you so much for the help! I thought about changing the style, but the problem is that the work flow goes, a person manually checks an mtext or multileader, corrects anything that is incorrect, then turns the text red to indicate that it is correct and has been checked. Then after everything has been checked, I place them back on the bylayer. It isn't a huge deal, I might just add a check into the command so that the user can't select objects that have fields in it.
Share this post
Link to post
handasa
here a one i used from afralisp.com
(defun c:colorchange ( / ssg)
(setq ssg (ssget))
(chc ssg 1) ;;; 1 for red color
(defun chc (sset color)
;load the visual lisp extensions
(vl-load-com)
;check for selection
   ;set up the counter
   (setq ctr 0)
   ;count the number of entities and loop
   (repeat (sslength sset)
       ;extract the entity name
       (setq item (ssname sset ctr))
       ;convert to vl object
       (setq item (vlax-ename->vla-object item))
         ;check if the entity has a color property
       ;and it can be updated
       (setq check (vlax-property-available-p item "Color" T))
       ;if it can
       (if check
           ;change it's color
           (vlax-put-property item 'Color color)
       );if
       ;increment the counter
       (setq ctr (1+ ctr))
   );repeat
);defun
Share this post
Link to post
hzdriggers
I'm trying to set the text color of the mleaderstyle using the following with no luck... but it seems you may be able to help me...
(setq *doc* (vla-get-activedocument (vlax-get-acad-object)))
(setq mldrdict (vla-item (vla-get-dictionaries *doc*) "ACAD_MLEADERSTYLE"))
(setq newldrstyle (vlax-invoke mldrdict 'addobject "Standard" "AcDbMLeaderStyle"))
(vlax-put-property newldrstyle 'AlignSpace 0.18)
(vlax-put-property newldrstyle 'Annotative -1)
(vlax-put-property newldrstyle 'ArrowSize 0.125)
(vlax-put-property newldrstyle 'BlockConnectionType 0)
(vlax-put-property newldrstyle 'BlockRotation 0.0)
(vlax-put-property newldrstyle 'BlockScale 1.0)
(vlax-put-property newldrstyle 'BreakSize 0.125)
(vlax-put-property newldrstyle 'ContentType 2)
(vlax-put-property newldrstyle 'Description "Standard")
(vlax-put-property newldrstyle 'DoglegLength 0.125)
(vlax-put-property newldrstyle 'DrawLeaderOrderType 0)
(vlax-put-property newldrstyle 'DrawMLeaderOrderType 1)
(vlax-put-property newldrstyle 'EnableBlockRotation -1)
(vlax-put-property newldrstyle 'EnableBlockScale -1)
(vlax-put-property newldrstyle 'EnableDogleg -1)
(vlax-put-property newldrstyle 'EnableFrameText 0)
(vlax-put-property newldrstyle 'EnableLanding -1)
(vlax-put-property newldrstyle 'FirstSegmentAngleConstraint 0)
(vlax-put-property newldrstyle 'LandingGap 0.125)
(vlax-put-property newldrstyle 'LeaderLineType 1)
(vlax-put-property newldrstyle 'LeaderLineTypeId "ByLayer")
(vlax-put-property newldrstyle 'LeaderLineWeight -1)
(vlax-put-property newldrstyle 'MaxLeaderSegmentsPoints 0)
(vlax-put-property newldrstyle 'name "Standard")
(vlax-put-property newldrstyle 'ScaleFactor 1.0)
(vlax-put-property newldrstyle 'SecondSegmentAngleConstraint 0)
(vlax-put-property newldrstyle 'TextAlignmentType 0)
(vlax-put-property newldrstyle 'TextAngleType 1)
(vlax-put-property newldrstyle 'TextHeight 0.09375)
(vlax-put-property newldrstyle 'TextColor Yellow)
(vlax-put-property newldrstyle 'TextLeftAttachmentType 1)
(vlax-put-property newldrstyle 'TextRightAttachmentType 1)
(vlax-put-property newldrstyle 'TextString "")
(vlax-put-property newldrstyle 'TextStyle (getvar "textstyle")))
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
