Viewport help...
How do you create a viewport from a custom shape?
For example, if I draw a rectangle I can then select 'convert object to viewport' but if I explode the rectangle, change the shape slightly and click on 'convert object to viewport' again, it will not convert as it is exploded.
I thought drawing a polyline would work but no joy. I'm sure this is something very simple but I am new to advanced viewports! :-)
Try using VPCLIP instead of exploding Viewport.. does this work for you?
No, when I try that it says Object selected was not a viewport?
This is in my layout tab.
EDIT:
Sorry, I know what you mean now. I've sorted it. Thanks a lot mate.
No worries Ste glad to be a help o:)
