Is there a lisp, changing solid hatch, to outline(pline global width 2mm)
,in the whole drawing also when it is in a block.
Edited by CAD
Hello Bigal u good:P!!, is a nice lisp, but need some modified, i have say solid hatch, but i think, i need it for all the hatches, sorry for that:geek:.
-The lisp ask select object, can u make it, that do instant for all the hatches in and outside the blocks, without asking.
-When it make outline the layer is 0, can u make a layer called outline
Looking somewhere else came across this little gem done by the Master Lee-mac in 2011. Change the 0.0 to what you want.
; original code by lee-mac 2011 zero pline in blocks
; just need this bit
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq obj (vlax-ename->vla-object (entlast)))
(if (eq "AcDbPolyline" (vla-get-objectname obj))
(vl-catch-all-apply 'vla-put-constantwidth (list obj 0.0))
(vla-regen doc acallviewports)
(vl-load-com) (princ)
Edited by BIGAL
Hello Bigal,
lisp get some
Error: bad argument type: VLA-OBJECT nil
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
hello B,
lisp loaded but nothing happen no error more :) but the things don't
-instant all hatch with outline (pline global width 2mm) without ask select objects.
-create outline layer name outlines
Do i miss something?
Edited by CAD
