Does anybody know if it is possible to get 2D drawing converted from Navis work modeling? Thanks.
Once I made a phasing using 2d elements. I think it is possible to show 2d in Navisworks. What results do you get, using what as input?
hi Halam, little confuse, i have 3D modeling from Navis work and i want to export/convert from that 3D to 2D top view or 3 ortho viewiews. how can i do that? Thanks
Sorry. I was thinking 2d as input.
Little to no export or conversion possible from Navisworks.
You can use .nwc as underlay in AutoCAD or Rev'it and do your thing in one of these.. (?)
As Hans has already mentioned, if you have AutoCAD 2018 you can XREF an NWC file. It may be a manual process but it may or may not work. I've never actually tried it but worth a shot.
-TZ
Better Ask for the native CAD files then fooling around with nwc..
