AutoCad Mechanical 2009 - how to set text size for Dimension
Hello: I recently received a newer version of autocad 09 and cannot
find how to set the text size for a Dimension.
I've been looking in help, but still am unable to figure it out.
Thanks,
Proctor
On the Ribbon click on the Annotate tab. Then on the Dimension panel look in the upper right hand corner. Click on the icon for Dimension Style. When the Dimension Style Manager dialog box appears click on the Modify button (to the right), then click on the Text tab. On the Text tab look for words Text height. Enter your value. Click the OK button at the bottom of the dialog box. Got it?
Remark: thanks for your reply. Forgive me .... I do see the Annotate off the menu bar, but your said "on the ribbon click" which I think you might have mean right click? at any rate, if i right click it, i only see "display menu bar"
perhaps there's another annotate tab?
thanks for helping.
Proctor
Proctor: I need some enlightenment. The main heading of your thread refers to Mechanical 2009. Your profile mentions straight AC 2006. Which one are we using here?
I'm running straight AC 2009 in a 2D workspace. My Ribbon has the following tabs (black background with white letters) from left to right: Home, Blocks & References, Annotate...etc. If I click on the Annotate tab my panels read, from left to right: Text, Dimensions, Multileaders, etc.
ReMark: I'll have to update my profile. some time ago, I began in 06 but am now using Mechanical 09.
Sorry for the confusion.
Proctor
