Hello,
My biggest prob with 3D in autocad is orbiting. I either use shift and middle mouse alone or navbar orbit tool and then shift and middle mouse. Is this it? It is really not too friendly as of now.
How is it not too friendly for you? Shift+Middle Mouse Button is it, but this is similar to other CAD applications.
How are you expecting it to function? Maybe we can help adjust some process for you.
-TZ
I use solidworks. inventor and revit and i have no problem. Autocad seems to just not wanna orbit as efficiently. I move ucs to a corner that kind of helps. While I am at it. Cant figure out a way to hit a face or surface of an object and be right on its plane. Not sure if its possible here. The whole plane thing is a mess and unorganized it seems.
lol, today orbit seems to work better. I started 3d template and opened file from there
i am fine with the shfit. 3dorditctr will save a boat load of time. Thanks
3dorbitctr is just as fast as hitting f4 if you went that route
