Need x and y values
cawokah17
You could explode the polyline (so it becomes a LINE) and use EATTEXT to export the starting X and Y points of each line to an excel document. You would mis the last X and Y point though this way, so you need to add it manually or also select the end X and Y points and just delete what you don't need in excel (or some other spreadsheet program).
Just add the write the answer out to this, the co-ords are in a list as (x y) for 2d plines or just use the getcords as a list of (x y x y x y)
; pline co-ords example
; By Alan H
(defun getcoords (ent)
 (vlax-safearray->list
   (vlax-variant-value
     (vlax-get-property
   (vlax-ename->vla-object ent)
   "Coordinates"
(defun co-ords2xy ()
; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
(setq numb (/ (length co-ords) 2))
(setq I 0)
(repeat numb
(setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
(setq co-ordsxy (cons xy co-ordsxy))
(setq I (+ I 2))
; program starts here
(setq co-ords (getcoords (car (entsel "\nplease pick pline"))))
(co-ords2xy)
; look at varaible co-ordsxy which is a list of vertices
(princ co-ordsxy)
Try this:
(defun c:foo ( / s )
 (if (and (setq s (car (entsel "\nSelect a LWpolyline :")))
          (member '(0 . "LWPOLYLINE") (setq s (entget s)))
   (foreach pt s
     (if (= (car pt) 10)
       (mapcar 'princ (mapcar 'strcat '("\nX=" " Y=")  (mapcar '(lambda (x) (rtos x 2)) (cdr pt))))
   (princ "\nNothing selected or invalid selection <!>")
Hi, try this:
; LWPOLYLINE's coordinates to excel
; Credits to: Lee Mac
(defun C:test ( / GroupN e xlapp xlwbs xlwbk xlsht xlcells xlrng msg )
 (defun GroupN ( n L )
   ( (lambda (f) (f n L))
     (lambda (n L) (cond ( (not L) L) ( (cons ((lambda ( / tmp ) (repeat n (setq tmp (cons (car L) tmp)) (setq L (cdr L))) (reverse tmp))) (f n L)) ) ) )
 (cond
   ( (not (setq e (car (entsel "\nPick LWpolyline: ")))) (prompt "\nNo selection.") )
   ( (not (wcmatch (cdr (assoc 0 (entget e))) "LWPOLYLINE")) (prompt "\nInvalid object.") )
   ( (not (setq xlapp (vlax-get-or-create-object "Excel.Application"))) (prompt "\nUnable to interfere with Excel application.") )
   ( ; (apply 'strcat (mapcar 'chr '(87 114 105 116 116 101 110 32 98 121 32 71 114 114 114)))
     (vl-catch-all-error-p
       (setq msg
         (vl-catch-all-apply
           (function
             (lambda ( / i )
               (setq xlwbs (vlax-get-property xlapp 'Workbooks))
               (setq xlwbk (vlax-invoke-method xlwbs 'Add))
               (setq xlsht (vlax-get-property  xlapp 'ActiveSheet))
               (setq xlcells (vlax-get-property xlsht 'Cells))
               (setq i 1)
               (mapcar
                 (function
                   (lambda (x)
                     (vl-catch-all-apply 'vlax-put-property (list xlcells 'Item i 1 (car x)))
                     (vl-catch-all-apply 'vlax-put-property (list xlcells 'Item i 2 (cadr x)))
                     (setq i (1+ i))
                 (GroupN 2 (append (list "X" "Y") (mapcar '(lambda (x) (rtos x (getvar 'lunits) (getvar 'luprec))) (vlax-get (vlax-ename->vla-object e) 'Coordinates))))
               ); mapcar
               (setq xlrng (vlax-get-property xlsht 'UsedRange))
               (mapcar '(lambda (prp) (vl-catch-all-apply 'vlax-put-property (list xlrng prp -4108))) '(VerticalAlignment HorizontalAlignment)) ; xlCenter = -4108
               (vlax-put-property xlapp 'Visible :vlax-true)
     (prompt (strcat "\nError: " (vl-catch-all-error-message msg)))
 ); cond
 (mapcar (function (lambda (x) (if (eq (type x) 'VLA-OBJECT) (vlax-release-object x)))) (list xlapp xlwbs xlwbk xlsht xlcells xlrng) )
); defun C:test
You could use a special VLISP program as noted above but if one is not available I would suggest you reconsider using the LIST command and do a copy-paste into Excel. In Excel click the Data tab and then the Text to Columns option and specify a space delimited file and you will have the x and y coordinates of the polyline in separate columns.
Try this:
(defun c:foo [/quote]
hi Tharwat please look at the 2nd image,
img2= [url="https://drive.google.com/open?id=0B1...E9qdmpBLWcxWHM"]https://drive.google.com/open?id=0B1...E9qdmpBLWcxWHM[/url]
i think OP needs something without prefix "N=" or "E=" ?
[code]
(defun c:xytest (/ f fn i l ss)
;hanhphuc 18.09.2017
;test w/o *error*
(if
(and
(setq ss (ssget "_+.:S:E"'((0 . "LWPOLYLINE"))))
(setq i -1 l (vl-remove-if-not ''((x)(listp (cdr x)))(entget (ssname ss 0))))
(setq fn (strcat (getvar 'tempprefix)"XY.csv"))
(setq f (open fn "w")))
(write-line "X,Y" f)
(repeat (1-(length l))
;;;(print (vl-string-translate "() ""  ,"(vl-princ-to-string(cdr(nth i l)))) f)
(write-line (apply 'strcat (mapcar ''((x)(strcat (rtos x 2)",")) (cdr(nth (setq i (1+ i)) l)))) f)
(if f (close f))
(vl-cmdf "start" fn)[color="green"]; if default "*.csv" associated to EXCEL, but slow performance[/color]
(startapp "notepad" fn)[color="green"]; recommended fastest[/color]
);progn
(princ "\nOops! LWPOLYLINE please.. ")
(vl-list->string '( 76 79 76 ) )
That was just a humbly info, with no commercial purpose. :)
Anyway I always forget about the vl-list->string function, more used with the (apply 'strcat (mapcar 'chr ...)) approach.
Not sure if OP wanted the output to excel, just thought to cover up my practice in this section of lisp.
nothing wrong you've provided a vanilla method, just curious the hidden message, it was creative :lol:
  • 1 month later...
