kippax
Blocks and attributes / tags
kippax
I have a drawing with multiple blocks that haves associated text.
All items in the block are on the same layer and they are also inserted into the drawing on the same layer in which they are created.
The associated text has been edited in the block editor to ensure that the text type and colour is consistent across the drawing.
However, when the block is inserted both the colour and type of text varies.
I can select each individual block and edit these properties, but there are hundreds of them on the drawing. Why doesn't it come in as selected in the block editor?
Share this post
Link to post
SLW210
Hard to say without seeing the blocks and the drawing they are being inserted into.
Share this post
Link to post
ReMark
After editing the block in the block editor and returning to the drawing did you run the ATTSYNC command?
Share this post
Link to post
kippax
OK sorted this now ..... Block re-constructed in Layer 0...
... and then REMEMBERED THE ATTSYNC COMMAND.
Think I have had reminders about exactly this before .... and possibly from your good self ReMark.
I am officially an "NoMark".
Share this post
Link to post
ReMark
Add the command to your AutoCAD Tips and Tricks list.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
