TunzaGibbo Posted November 7, 2017 Share Posted November 7, 2017 I want to draw a line and add an arrow head to the end of the line. I can do this easily but when I pick the grip point on the opposite end to the arrow and move this point in any direction the arrow doesn’t rotate with the line. Is there a way that I can add some code to my lisp routine to make the arrow part of the line? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 7, 2017 Share Posted November 7, 2017 I have moved your thread to the AutoLISP, Visual LISP & DCL Forum since you are wanting help with a LISP. Quote Link to comment Share on other sites More sharing options...
Aftertouch Posted November 7, 2017 Share Posted November 7, 2017 Why dont you just use a LEADER Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted November 7, 2017 Share Posted November 7, 2017 Welcome to the CADTutor forum. As Aftertouch indicates, a leader or multi-leader will give you a line with an arrow that stay aligned with each other. If you don't want text, you can select Options instead of typing text and use the None option. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 7, 2017 Share Posted November 7, 2017 I use QLEADER when I just want a line with an arrow, but the OP mentions this is part of a LISP routine. THIS may help. Quote Link to comment Share on other sites More sharing options...
