MahReda
Make User Variable From Mtxt
MahReda
Dear Sir's
I want to make user variable "Let's say USER1" to be equal to number 15 which is written in txt or mtxt anywhere in my drawing
so if anyone change this txt or mtxt to 16 the USER1 will be changed to 16 also
I hope my explanation was clears enough
thanks and regards
Share this post
Link to post
BIGAL
You would be better of with using xdata rather than the USER variables just needs some else code to use it and it wrong.
Share this post
Link to post
MahReda
Dear sir
Thanks for your help
here is my full idea
i made this diesel expression
$(substr,$(getvar,dwgname),1, $(getvar,"USERI1"))
i have set custom variable called USERI1 to 11
so this expression is to give me the first 11 letters in my drawing name
all i need is to have some flexibility to change the number of letter i get from my drawing name
i'm not familiar of xdata function
can i use the xdata with diesel expression and how ?
Regards
Share this post
Link to post
tombu
I assign many values to custom Drawing Properties and reference them with fields. Then if I need to change for example the number of pages or name of the engineer of record I simply do it in Drawing Properties and it's updated everywhere automatically. You can do the same with Custom Sheet Set Properties.
Share this post
Link to post
tombu
I've added a drop-down in my Ribbon with lisp macros for the Propulate command like:
^C^C(command "Propulate" "A" "D:/Users/BeaufordT/AppData/Roaming/Autodesk/VLisp/TomBeauford.prp" "U" "C")
to set my name as the Drawn by and my boss as the Engineer of Record who's going to sign and seal the drawings.
Share this post
Link to post
Roy_043
@MahReda:
What part of the dwgname do you want to remove?
Note: You can directly reference the file name without the extension in a field.
Share this post
Link to post
ecustis
Dear Sir's
thanks and regards
I would suggest using fields like Tombu mentioned.
This is exactly what we do, custom properties and pieces of text/mtext that have fields that reference the custom properties. I love it, saves so much time.
Share this post
Link to post
Aftertouch
Why dont you use the macromode variable?
Share this post
Link to post
MahReda
@MahReda:
i want to show first 11 letter of the drawing name
but unfortunately in some drawings i need to show only 10 or 9 letters
Share this post
Link to post
MahReda
Can u explain to me how to do this ??
Share this post
Link to post
Aftertouch
Type command DWGPROPS. These settings can be shown on screen with fields.
Share this post
Link to post
tombu
Like Aftertouch said you can add custom variables and values in DWGPROPS. The Express Tools command PROPULATE alows you to quickly load a complete set of property variables and values saved in a prp file. It's used by lots of CAD people and there's a bit of lisp written for modifying them as well.
Share this post
Link to post
MahReda
ok now i set new dwgprop named DN and equal to 11
when i use it in diesel expression like this
$(substr,$(getvar,dwgname),1, %%)
it works fine but when i save and close then open my file again i find that the diesel expression turned into
$(substr,$(getvar,dwgname),1, 11)
so if i changed my DN variable again, diesel expression will never be changed automatically
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
