Shady_Potato Posted November 20, 2017 Share Posted November 20, 2017 Greetings, Im working on a test lisp to see if I can automate binding an existing xref & converting a bounded block reference back into an xref. while I was able to automate bind, I realized the express tool (-blocktoxref) is incompatible with lisp as it cant seem to find the command. Then I created a script that allows me to set up an open command, but I cant seem to use my local variables (BLKNAME & NEWFILEPATH) with the script command. So my question is, Is it possible to write a script via lisp? and if so how? (defun c:ws_Layer_copy () (vl-load-com) (setq en (ssget "x" '((0 . "insert") (8 . "XREF - ELECTRICAL - 1")))) (setq ent (ssname en 0)) (setq EN (entget ent)) (setq layno (vl-string-left-trim "XREF - ELECTRICAL - " (cdr(assoc 8 EN)))) (setq dwgpath (getvar "dwgprefix")) (setq dwgname (getvar "dwgname")) (setq nametrim (vl-string-right-trim "HVAC LAYOUT.dwg" dwgname)) (if (= layno "1") (setq layname "1st") ) (if (= layno "2") (setq layname "2nd") ) (if (= layno "3") (setq layname "3rd") ) (if (= layno "4") (setq layname "4th") ) (if (= layno "5") (setq layname "5th") ) (setq newfilepath (strcat nametrim layname " Floor Electrical" )) (setq blkname (vl-string-left-trim dwgpath newfilepath)) (command "-xref" "bind" newfilepath ) ;---------------------------------------------------------------------- (command "script" "blocktoxref.scr" ) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 21, 2017 Share Posted November 21, 2017 A lot of the express tools can be accessed via lisp you need though to look in the lisp code for express 2 come to mind extrim & Tcircle can be accessed but not by those names. Will try to find in lisp. Quote Link to comment Share on other sites More sharing options...
