steepcreeker Posted May 4, 2007 Share Posted May 4, 2007 I'm looking for a shareware hatch for wood grain. Something that will work for wood trim in details. There must be something free in the cyber world. I would perfer not to spend money on a lot of hatches that I will not use but a few. Thanks Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 4, 2007 Share Posted May 4, 2007 Did you try searching with Google? Using this search [ http://www.google.com/search?q=free%20autocad%20hatch%20wood ], I was able to find this in about a minute. http://groups.google.com/group/autodesk.autocad.drafting/msg/223900d112d64fb9 I'm sure there are more out there also if those patterns don't fit your needs. Quote Link to comment Share on other sites More sharing options...
steepcreeker Posted May 4, 2007 Author Share Posted May 4, 2007 I did find a pattern I like, now where do I put the .pat files and the slide Library files so autocad will recognize them in the dialog box? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 4, 2007 Share Posted May 4, 2007 I have full Autocad and I keep mine here: C:\Documents and Settings\"Your Name Here"\Application Data\Autodesk\AutoCAD 2006\R16.2\enu\Custom\Hatch "Custom" and "Hatch" are folders that I created within the "enu" folder. Quote Link to comment Share on other sites More sharing options...
hazardman Posted May 4, 2007 Share Posted May 4, 2007 you don't need the slide library anymore (after release 14)...simply place the *.pat file in a directory that is defined in the support file serach path in the options...i usually keep my custom hatches in a separate folder (just to keep things tiddy) but i think you could simply copy it to the support directory in acad... Quote Link to comment Share on other sites More sharing options...
Squirrel Cottage Posted May 4, 2007 Share Posted May 4, 2007 Hi Streepcreeker Being a cabinet maker and do my own designs I use wood hatch patterns to bring my drawings to life. So I recommend that you consider splashing out around $29 and purchase a set from this guy. http://hatchpatterns.com/ and a example of their use can be found at http://rapidshare.com/files/28566502/Wardrobe.dwg.html Alan Quote Link to comment Share on other sites More sharing options...
Guest Alan Cullen Posted May 5, 2007 Share Posted May 5, 2007 You can also copy your hatch pattern definitions to the end of the acad.pat file under the section user defined hatch patterns.....that way they will migrate when you do an upgrade of acad. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 7, 2007 Share Posted May 7, 2007 that way they will migrate when you do an upgrade of acad. Disclaimer... Only if you allow AutoCAD to do the migration for you. Many users answer NO to this question to avoid surprises. Quote Link to comment Share on other sites More sharing options...
Dibz Posted September 23, 2010 Share Posted September 23, 2010 I know this is an old thread But it touches on what I need. A simple wood end Hatch... I have followed the above links which lead to what I thorght was what I wanted but it causes error when loading. "error in patern file" I realy need a wood hatch that looks like the end of a board. Can someone help me PLS... Thankyou in advance... Quote Link to comment Share on other sites More sharing options...
