100Jan
How to add My Application folder to TRUSTEDPATH
100Jan
I have Created Setup Program for my application.
Application install fine and first VLX File load on Startup.
Lock2Block.vlx
Lock2BlockCmds.vlx
(defun Lock2Block-GetAppFolder ()
 (vl-string-right-trim "\\/"
   (cond ; Check all three possible registry locations
     ( (vl-registry-read "HKEY_CURRENT_USER\\Software\\MProjekt\\Lock2Block" "InstallPath")
     ( (vl-registry-read "HKEY_LOCAL_MACHINE\\Software\\Mprojekt\\Lock2Block" "InstallPath")
     ( (vl-registry-read "HKEY_LOCAL_MACHINE\\Software\\Wow6432Node\Mprojekt\\Lock2Block" "InstallPath")
;; Define autoload command stubs
;; * "Lock2BlockCmds" is the lisp filename that implements the commands
(autoload (strcat (vl-string-translate "\\" "/" (Lock2Block-GetAppFolder)) "/" "Lock2BlockCmds")
  "L2B"
  "UNDOL2B"
 (lambda (/ trustedpaths appfolder startpos endpos found)
   (if (setq trustedpaths (getvar "TRUSTEDPATHS"))
       (setq appfolder (Lock2Block-GetAppFolder))
       (while (and (not found) (setq endpos (vl-string-position (ascii ";") trustedpaths endpos)))
         (setq found
           (eq
             (strcase appfolder)
             (strcase
               (substr
                 trustedpaths
                 (if startpos startpos (setq startpos 1))
                 (- (setq endpos (1+ endpos)) startpos)
         (setq startpos (1+ endpos))
       (if (not found) (setq found (eq appfolder (substr trustedpaths (if startpos startpos 1)))))
       (if (not found) (setvar "TRUSTEDPATHS" (strcat trustedpaths ";" appfolder)))
(princ "\nLock2Block loaded -- Command L2B and UNDOL2B are now available.\n")
But when i try to Run command L2B from VLX file, I recieve error.
The file /Lock2BlockCmds(.lsp/.exe/.arx) was not found in your search path
folders.
Check the installation of the support files and try again.nil
So I guess My APP Folder is not in AutoCad TrustedPaths.
Is there any way to put App Folder to TrustedPath ?
Share this post
Link to post
Grrr
Heres two interesting links:
Add to Trusted Locations via lisp
Add & Remove Support File Search Paths
This is the conclusion I'm doing from the first link:
(defun AddTrustedPaths ( Lpaths / v )
 (and
   Lpaths
   (setq v (apply 'strcat (cons (cond ( (setq v (getvar 'trustedpaths)) (strcat v ";") ) ("")) (mapcar '(lambda (x) (strcat x ";")) Lpaths))))
   (setvar 'trustedpaths v)
); defun AddTrustedPaths
But I'm not sure if it works.
EDIT: With brief testing seems to work: (AddTrustedPaths (list (acet-ui-pickdir)))
Edited by Grrr
Share this post
Link to post
rlx
 (and
   Lpaths
Never searched for this but now I see it I'm gonna use it , thanx Grrr!
Gr. Rlx
Share this post
Link to post
Grrr
Gr. Rlx
Me too, I was just aware only of Lee's LM:sfsp+ function, so its kinda new for me aswell. :)
Share this post
Link to post
BIGAL
I have set just about everything else and the missing one was so simple. Thanks Grrr. When we build a new pc just run the lisp Trusted paths was missing.
Share this post
Link to post
Grrr
No worries, BIGAL - the guys in that thread deserve the credit - the rest is just a bit of manipulation.
Share this post
Link to post
Grrr
I think this one would be better, since its more generic:
; n - position to insert, if nil - it would be the very last
; dir - directory to add
; where - (getvar 'trustedpaths) or (getenv "ACAD") or..
; returns: string with the included directory at nth position
; example: (setvar 'trustedpaths (InsertDir nil (acet-ui-pickdir) (getvar 'trustedpaths)))
(defun InsertDir ( n dir where / f paths i r )
 (cond
   ( (not (vl-every '(lambda (x) (eq 'STR (type x))) (list dir where))) )
   ( (progn (setq paths ((setq f (lambda ( s / i ) (if (setq i (vl-string-search ";" s)) (append (list (substr s 1 i)) (f (substr s (+ i 2)))) (list s)))) where)) nil) )
   ( (eq 'INT (type n)) (setq i -1)
     (setq r
       (if (< n (length paths))
         (apply 'strcat (apply 'append (mapcar (function (lambda (x) (setq i (1+ i)) (if (= i n) (list dir ";" x ";") (list x ";")))) paths)))
         (strcat where ";" dir)
   ( (setq r (strcat (apply 'strcat (mapcar '(lambda (x) (strcat x ";")) paths)) dir)) )
 ); cond
 r
); defun InsertDir
Edited by Grrr
Share this post
Link to post
100Jan
Uuu nice :) Its working... tnx Grrr... At last my code is complete. Now just upgrades :) BTW Ne of the best place here to seek help...
Share this post
Link to post
100Jan
One more Question:
If I read installation Path from registry with this code
Is there any way to load specific *.VLX from this directory
EXAMPLE:
Something like this
(vl-load-all (Lock2Block-GetaAppFolder) "Lock2BlockCmds.vlx")
because i don't know directory where user will install Application. So I want to read install path from registry and then load specific vlx from this directory...
Sorry i'm new to Lisp :(
Share this post
Link to post
Grrr
After obtaining the path use load function in conjuction with vl-directory-files, or if you want to load from subdirectories aswell, then you'll need recursive subfunction like this.
Makes me think does the trustedpath will support the subdirectories aswell. :thinking:
Share this post
Link to post
BIGAL
100jan if you want things to work all the time then you need some rules, you need to create a installer so you know where the software is, you can use lisp or a a Bat file.
; make temp directory
(if (vl-file-directory-p "C:\\Acadtemp\\")
(Princ "Acadtemp exists")
(vl-mkdir "C:\\AcadTEMP\\")
here is something useful for upgrades.
; resets the paths 2016 usefull for update versions of Autocad
; by Alan H 2016
; This sets a reference to the install path of your product
; the gets are their for info maybe other use
; use this to find other settings
;(vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-Acad-object))) T)
(vl-load-com)
(defun setpaths ( / *files* doc)
(setq *files*  (vla-get-files  (vla-get-preferences (vlax-get-Acad-object))))
; savepath
;(vla-get-AutoSavepath *files*)
(vla-put-AutoSavepath *files* "C:\\AcadTemp")
; custom icons
;(vla-get-CustomIconPath *files*))
(vla-put-CustomIconPath *files* "P:\\Autodesk\\ICONS")
; custom menu
;(vla-get-Menufile *files*))
;(vla-put-Menufile  *files* "C:\\Users\\2013XXXX")
; printers config
;(vla-get-PrinterConfigPath *files*)
(vla-put-PrinterConfigPath *files* "P:\\AutoDESK\\Plotting\\Plot Styles 2011")
; printers style sheet
;(vla-get-PrinterStyleSheetPath *files*)
(vla-put-PrinterStyleSheetPath *files* "P:\\AutoDESK\\Plotting\\Plot Styles")
; printer drv's
;(vla-get-PrinterDescPath *files*)
(vla-put-PrinterDescPath *files* "P:\\AutoDESK\\Plotting\\Drv")
; print spooler
;(vla-get-PrintSpoolerPath *files*)
(vla-put-PrintSpoolerPath *files* "C:\\AcadTemp\\")
; template  path
;(vla-get-TemplateDwgPath *files*)
(vla-put-TemplateDwgPath *files* "P:\\Autodesk\\c3d Templates")
; template location
;(vla-get-QnewTemplateFile *files*)
(vla-put-QnewTemplateFile *files* "P:\\Autodesk\\c3d Templates\\XXXX.dwt")
;make new support paths exist + new
(setq paths (vla-get-SupportPath *files*))
(setq XXXXpaths "P:\\autodesk\\supportfiles;P:\\autodesk\\lisp;P:\\autodesk\\fonts;")
(setq newpath (strcat XXXXpaths paths))
(vla-put-SupportPath *files* newpath)
; Tempdirectory
;(vla-get-TempFilePath *files*))
(vla-put-TempFilePath *files* "C:\\AcadTemp\\")
;   PlotLogFilePath = "C:\\Documents and Settings\\whoisit.XXXX-AD\\localsettings\\application data\\autodesk\\c3d 2011\\enu\\"
(vla-put-PlotLogFilePath *files* "C:\\AcadTemp\\")
;   LogFilePath = "C:\\Documents and Settings\\whoisit.XXXX-AD\\localsettings\\application data\\autodesk\\c3d 2011\\enu\\"
(vla-put-LogFilePath *files* "C:\\AcadTemp\\")
; xref temp path
;(vla-get-TempXrefPath *files*))
(vla-put-TempXrefPath *files* "C:\\AcadTemp\\")
; end use of *files*
(setpaths)
; exit quitely
(princ "All Done")
Share this post
Link to post
100Jan
I made installer with Inno Setup. Program install ok and write data in registry. I use ARX Loader for program to start on AutoCad startup. Everithyng work fine with .lsp files. But when i set script to install vlx files, second vlx from install directory won`t load. I have two files First one to read registry, Make trusteth path, and set path to second command vlx file.
So i think all i need is to call ssecond file with load function from installed directory.
But problem is i dont know where user will install this program so i dont know where is the file. I must search with this code in earlier post GetAppFolder... And then somehow load vlx file.
Share this post
Link to post
Roy_043
@100jan:
The function vl-list-loaded-vlx can be used to determine the path of a loaded vlx file. It may be useful in your scenario.
Share this post
Link to post
Grrr
This made me curious about a similar function that works for lsp files.
EDIT: Just found this snippet, which will retrieve the folder of the last apploaded lisp (not sure if that works with .vlx):
(defun last-appload-folder ( )
 ; LM ; http://www.cadtutor.net/forum/showthread.php?82830-List-of-a-loaded-lisps&
 (vl-registry-read (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar 'cprofile) "\\Dialogs\\Appload") "MainDialog")
Edited by Grrr
Share this post
Link to post
100Jan
I managed to do it with Merging All needed *.lsp and *.dlc into one vlx file. And then in Inno Setup Script changed all Registry path and .arx function to this *.vlx.
Now Setup Install Program in (Program Files (x86) default) and then Auto Load This File when AutoCad strats, and everything working.
But i will try to figure out how to load all needed vlx, dll... files from one main vlx.
I have found this link http://www.manusoft.com/resources/arxtips/demandloadvlx.html
Thx everyone for help and happy Coding holidays :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
