gsc
Insert list2 in list1 at certain position
gsc
I have 2 lists:
List1 (0.0 -0.196738 0.0 0.196738 0.0 0.0)
List2 (-0.059895 0.120221 -0.059895 0.0)
I want to insert List2 in List1 at a certain position:
NewList (0.0 -0.196738 0.0 -0.059895 0.120221 -0.059895 0.0 0.196738 0.0 0.0)
In this case at position nth 3
How do I do this?
Share this post
Link to post
Tharwat
Hi,
Just an example for you comprehend the process:
(setq list1 '(0.0 -0.196738 0.0 0.196738 0.0 0.0)
     list2 '(-0.059895 0.120221 -0.059895 0.0)
(setq position 3)
(setq run 0)
(foreach item list1
 (if (= (setq run (1+ run)) position)
   (foreach element list2
     (setq lst (cons element lst))
   (setq lst (cons item lst))
Share this post
Link to post
Tharwat
Another if you want to. :)
(setq pos 3)
(mapcar '(lambda (u) (if (= (length lst) pos) (mapcar '(lambda (x) (setq lst (cons x lst))) list2)
                      (setq lst (cons u lst))))
       list1)
Share this post
Link to post
Lee Mac
For example:
(defun foo ( new pos lst / tmp )
   (repeat pos (setq tmp (cons (car lst) tmp) lst (cdr lst)))
   (append (reverse tmp) new lst)
_$ (setq l1 '(0 1 2 3 4 5))
(0 1 2 3 4 5)
_$ (setq l2 '("a" "b" "c"))
("a" "b" "c")
_$ (foo l2 3 l1)
(0 1 2 "a" "b" "c" 3 4 5)
Share this post
Link to post
Stefan BMR
A recursive solution
(defun inslist (l1 n l2 / f)
 (defun f (l n)
   (if
     (and l (> n 0))
     (cons (car l) (f (cdr l) (1- n)))
     (append l2 l)
 (f l1 n)
(setq l1 '(0.0 -0.196738 0.0 0.196738 0.0 0.0)
     l2 '(-0.059895 0.120221 -0.059895 0.0)
(inslist l1 3 l2) -> (0.0 -0.196738 0.0 -0.059895 0.120221 -0.059895 0.0 0.196738 0.0 0.0)
Share this post
Link to post
Lee Mac
Or, without the subfunction -
(defun foo ( new pos lst )
   (if (and (< 0 pos) lst)
       (cons (car lst) (foo new (1- pos) (cdr lst)))
       (append new lst)
Share this post
Link to post
gsc
Thanx, all examples work!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
