hi every one
please any one tell me how i will convert cad design into image format.
A few ways to make a JPEG out of your CAD drawing. First is to use Printscreen, paste it into Paint, crop it, and save as JPEG. Second is the "Publish to web.jpg" printer option from the plot dialog box, basically plotting to file. Third is the JPGOUT command (not sure if its available in 2005) which will create a JPEG out of the selected objects based on your current window (I.E. zoom is a factor). Also be sure to check the similar threads at the bottom of the page. These are the results you will have received if you use the thread's title as a forum search.
Just type in JPGOUT into the command bar :wink:
thanks but in this way the image quality is very bad.
You might be looking into rendering then...
You can create a custom page size which allows you to crank the image quality up quite a bit.
Also, maybe you can use a .png instead, crank the resolution up on that one also.
