smorales02 Posted January 16, 2009 Posted January 16, 2009 I was under the impression that you can use this option as a text mask of some sort... I have it set to 'background' and it works visually on the screen but does not print like a text mask. Any ideas and/or insight would be appreciated Quote
MaxwellEdison Posted January 16, 2009 Posted January 16, 2009 Check your DRAWORDER. Is the dimension above the object it is supposed to be masking? Quote
smorales02 Posted January 16, 2009 Author Posted January 16, 2009 Draworder is set correctly. It seems to just not be printing the "fill color" Quote
MaxwellEdison Posted January 16, 2009 Posted January 16, 2009 Have you tried setting it to a different color, red for example? Quote
smorales02 Posted January 16, 2009 Author Posted January 16, 2009 I have not tried that, cause I need it to work like a text mask and im printing black and white. Quote
