Select texts & change color
help with error code
(defun c:somework ()
(setvar "cmdecho" 0)
(command "_.select" "Fence" "-0.6,1.127" "36.9,1.245" " ")
(command "_.change" "p" "c" "1")
Items selected with the fence method need to be visible on the screen.
Try something like this to remove command calls.
(defun c:foo (/ s)
 (if (setq s (ssget "_F" '((-0.6 1.127) (36.9 1.245))))
   (mapcar '(lambda (x) (entmod (append (entget x) '((62 . 1))))) (mapcar 'cadr (ssnamex s)))
(defun c:foo (/ s)
thanks a lot
if I want to add more lines
Example: (-0.274,3.183) (11.324,2.947)
A fence can be as many points as you like, if two seperate lines look into ssad running ssget as required.
(defun c:foo (/ s lst )
(setq lst '((-0.6 -1.127) (36.9 1.245) (-0.274 3.183) (11.324 2.947))) ; note comma removed
 (if (setq s (ssget "_F" lst ))
many thanks Bigal
Last question!
If I want to add different color, say color number 2 to this line (-0.6 -1.127) (36.9 1.245)
Try this:
(defun c:foo (/ s)
 ;; List of '((color point point)(color point point)...)
 (foreach l '((2 (-0.6 1.127) (36.9 1.245)) (1 (-0.274 3.183) (11.324 2.947)))
   (if	(setq s (ssget "_F" (cdr l)))
     (mapcar '(lambda (x) (entmod (append (entget x) (list (cons 62 (car l))))))
Do you have an example drawing of what you're trying to accomplish? This process seems a bit odd to me.
