llmarsh3 Posted February 8, 2018 Posted February 8, 2018 One block I have in a CAD file is not plotting right when made to a pdf. The text in the block is printed in huge and not inside of the center of the callout as it should be. Only this drawings. The other floors are ok. Any help? Block in model space and plotting in paperspace 1:1. thanks. Quote
SLW210 Posted February 9, 2018 Posted February 9, 2018 I have moved your thread to the AutoCAD Drawing Management & Output Forum. Hard to tell anything with that image, can you post the .pdf and a .dwg? Is the plot preview correct? Quote
CyberAngel Posted February 9, 2018 Posted February 9, 2018 As ReMark suggests, the source of your issue may be annotation. That's typically why I see this kind of behavior. Check the drawing's annotation scale versus that of the block text. You may have to add the current scale to the list of scales for the text. Quote
Ski_Me Posted February 15, 2018 Posted February 15, 2018 posting the drawing would help. Need to know the settings for the PDF printer. Could have the wrong size paper selected. Quote
