cat3appr Posted March 2, 2018 Posted March 2, 2018 Hello, Premise: nothing is wrong with my PC, good office machine. my Autocad2015 gets stuck on specific tasks, for example when i select a block within a DWG, when i open up a DWG larger than usual.. it just hangs there for a few minutes making every task really challenging.. how would I start to look to fix this? many thanks! Quote
ReMark Posted March 2, 2018 Posted March 2, 2018 When did the problem first occur? What changed recently? What is the source of the drawings you are attempting to open? Are drawing file sizes abnormally large? Do you routinely clean your drawings? This is a networked computer is it not? Does anyone else in the office have a problem opening the same drawings? Have you spoken to your IT department? What troubleshooting steps have you taken thus far? Quote
rkmcswain Posted March 2, 2018 Posted March 2, 2018 If you can repeat this delay on demand, then get ready to do so, then unplug your network cable (and make sure no WiFi connections are enabled) - then try again. Does the delay still happen? Quote
