cat3appr 10 Posted March 2, 2018 hi i need to manipulate objects on top of a hatch ( sitting in its layer) and each time the hatch gets selected is really annoying because i cant see and move the other object properly. is there a way to freeze the hatch from being selected when hoovering with the mouse on it? many thanks! Quote Share this post Link to post Share on other sites
ReMark 58 Posted March 2, 2018 Use a lisp routine that will hide objects only making them visible again once you have completed the task. Or.....you could have a dedicated layer called HATCH which could then be frozen or locked as you like. Quote Share this post Link to post Share on other sites
cat3appr 10 Posted March 2, 2018 of course i have the hatch on the layer. if i froze or lock it, it still gets selected when hovering into it Quote Share this post Link to post Share on other sites
Cad64 81 Posted March 2, 2018 I agree with ReMark. Just turn off the hatch layer while you're working and then turn it back on when you're done. Quote Share this post Link to post Share on other sites
ReMark 58 Posted March 2, 2018 of course i have the hatch on the layer. if i froze or lock it, it still gets selected when hovering into it To be clear....your hatch pattern is on its own layer, different than the layer the object you want to manipulate is on, and it still gets selected even if the hatch layer is frozen or locked? Quote Share this post Link to post Share on other sites
