cat3appr Posted March 4, 2018 Posted March 4, 2018 Hello, I have this map panel made by several blocks imported and constructed in CAD with an external utility. The KP box looks terrible when other blocks go through it, but I can't trim inside because the KP box is on the main DWG , while the other bjects that I'd like to trim are part of other blocks. Starting from the point that I can't alter the blocks - the DWG has to remain like this, with blocks. Is there a way to trim inside that KP box? many thanks! Alex WUWC43FS002.dwg Quote
cat3appr Posted March 5, 2018 Author Posted March 5, 2018 Have you looked at Wipeout ? wow fantastic! thanks! Quote
cat3appr Posted March 5, 2018 Author Posted March 5, 2018 Have you looked at Wipeout ? wow fantastic! thanks! basically first you moved the KP number outside, ( i need to keep the 1. wiped out and placed the KP back right? Quote
tombu Posted March 5, 2018 Posted March 5, 2018 wow fantastic! thanks!basically first you moved the KP number outside, ( i need to keep the 1. wiped out and placed the KP back right? Wipeout doesn't actually erase anything. After adding it simply select the KP number or anything you want visible and bring it to front with draworder. Quote
